Pix of Spacers on IS
Old 08-27-10, 11:31 AM
Pivo154
Pivo154's Avatar
Default Pix of Spacers on IS
Id like to se see pix of spacers on & off ride. I am wondering what is the biggest size spacers that can go on our cars? What spacers can sit the most flush on the car? Is 20mm in front & 25mm the perfect fit?
Old 08-27-10, 10:10 PM
Pivo154
Pivo154's Avatar
Bump...Someone has to have input on this subject...
Old 08-27-10, 10:14 PM
mikez
mikez's Avatar
Before 25mm spacers in the rear:
After:
Old 08-27-10, 10:44 PM
Hoovey689
Forum Moderator
Hoovey689's Avatar
^^^ Nice!!
Old 08-28-10, 10:05 AM
Pivo154
Pivo154's Avatar
Looks much better! Can the 25mm fit in rear w/o rubbing though? Will it be safe? As well as having 20mm in front?
Old 08-28-10, 10:12 AM
mikez
mikez's Avatar
25mm will fit in the back with OEM spec wheels with no rubbing, not sure about 20mm in the front.
Safety of the spacer depends on if its a reputable brand, properly torqued and adjusted, and how much thread left on your lugs to torque the nuts with.
Old 08-28-10, 03:20 PM
flexthatdx
flexthatdx's Avatar
I will only trust a reputable brand like H&R
Old 08-28-10, 04:32 PM
b2designs
Former Sponsor
b2designs's Avatar
Check out the Ichiba spacers. Nice quality spacer. Lots of members use them. Most popular for the IS is 15mm front and 20mm rear. 25mm with work also
https://www.clublexus.com/forums/clu...-5mm-25mm.html
Old 08-28-10, 07:14 PM
516IS
516IS's Avatar
Ichiban Spacers FTW...
Old 08-28-10, 11:49 PM
Jetfire
Royale with cheese
Jetfire's Avatar
i'm planniong to get H&R too. trust them more than ichiba.
Old 08-29-10, 02:00 PM
Pivo154
Pivo154's Avatar
Is there any good prices on the H&R spacers? Im still debating on wether to get 20mm or 25mm in rear. I really want that aggressive look but if the 25mm isnt safe for long time usage then I dont want it. I plan to use these for a while bc I dont plan to get aftermarket rims.
Old 08-29-10, 07:27 PM
Ki11switch
Ki11switch's Avatar
After:
Is that stock ride height or is it lowered.
Old 08-29-10, 09:56 PM
neova
neova's Avatar
I have Project KICS spacers (more like adaptors) 10mm front and 15mm rear on OEM 18" 225/40 and 255/40 tires on x-package suspension. When my trunk is loaded and 3-passengers are in the backseat the rear tires just barely clears the fenders so I'd say 15mm spacer is the most if you will be having a full load in the back seats and the trunk.
Whether our feedback will help you depends on what wheels/tires/suspension you're on?
Old 08-30-10, 06:43 AM
mikez
mikez's Avatar
I've had 5 people in my car along with the trunk filled with luggage for memorial day weekend and the car doesn't even rub, looks are deceiving.
Old 09-16-10, 01:49 AM
sw2oboi
sw2oboi's Avatar
are your fenders rolled?
xtremex626
General Classifieds
01-31-17 02:35 AM
Lexwon
Wheels and Tires Classifieds
12-29-11 06:16 AM
tungo
08-06-09 11:19 PM
RI-Lex
01-12-09 09:54 AM
SloGS400
11-11-07 11:27 AM
Quick Reply: Pix of Spacers on IS
