who here has them on their GS, i'm looking into the 15mm up front, any shake? loose steering feel? any handling improvements with the wider stance up front... i appreciate any input on this, thanks
I had them before. Just make sure you get hubcentric spacers and you should be fine. I noticed some slight handling improvements with 15mm in the front and 25mm in the rear.
hey man im thinking of getting some spacers for the rear of my car. im wondering if i should get 25mm spacers or even 30mm spacers on my stock wheels. do you have any pics of the 25mm's on your ride?
As chrispy said....any spacer you put on your GS...make sure they are hubcentric with 60.10 hub bore size....this will keep wheel vibration to a minimum when wheels are center mounted to the hub.
what would you guys reccomened me to get? The 25's or the 30's for the rear. I want to rear to be a little agressive. I can see that the 25mm spacers bring the wheel out just out straight to the gap of the rear wheel well. Do have a pic with the 25mm's in rear but from far from the back. I want to see the
stance.
