HID Headlights.
Old Aug 14, 2010 | 04:49 PM
JoeCombs's Avatar
JoeCombs
Default HID Headlights.
So i recently bought some d4s bulbs for my OEM HIDs and installed them myself, but when the car comes on it takes the driver side's light longer to reach its normal color (bulbs look blue when first turned on then go white) also about after 3min the driver side goes out. i searched around and could not find any answers so any guidance would be appreciated
Old Aug 14, 2010 | 05:43 PM
new.era.13's Avatar
new.era.13
aftermarket bulbs takes more energy and time. The going out part after 3mins, try switching the bulbs from driver side to the other side. that will tell you if the bulb is bad or the ballast it bad.
Old Aug 14, 2010 | 07:39 PM
JoeCombs's Avatar
JoeCombs
ok, i dont think it is a bulb thing because i have seen many other members here using the same bulb. nor the ballast because, well it is the Lexus OEM ballast. ill try switching the bulbs tonight.
Old Aug 14, 2010 | 07:40 PM
JoeCombs's Avatar
JoeCombs
one thing i forgot to mention is once i notice the light going out i just turn the lights on/off again and it will work for another 3min, so even if it is a bulb thing how come it will keep igniting?
Old Aug 14, 2010 | 08:23 PM
alan003's Avatar
alan003
what kind of brand is it? you should stick with reliable brands
Old Aug 14, 2010 | 08:28 PM
laobo979's Avatar
laobo979
i use d4s Philips Ultinon and i dont have any issue but my bulb are a bit pricey but well worth it to me
Old Aug 14, 2010 | 09:39 PM
new.era.13's Avatar
new.era.13
i had my lexus ballast go out when i changed my stock hid bulbs to DDM tuning bulbs. they replace the whole housing for me. It can be the bulb because the when you turn it off the gas cools down and than re-ignite. I had a friend that had a similar problem like yours.
Old Aug 14, 2010 | 10:04 PM
JoeCombs's Avatar
JoeCombs
i have xenon depots Extreme d4s 6k bulbs, i just drove around for a while, they went out twice in the beginning but then worked for 30+ min straight... weird. maybe they are fixed? how can that be explained? the only thing i can think of is maybe my battery was running low because i had my car (fully on) just sitting in my driveway, thus charging the battery for a while, then they worked.
Old Aug 14, 2010 | 10:06 PM
JoeCombs's Avatar
JoeCombs
Originally Posted by new.era.13
i had my lexus ballast go out when i changed my stock hid bulbs to DDM tuning bulbs. they replace the whole housing for me.\
lexus replaced it for free even though it was an aftermarket part?
Old Aug 14, 2010 | 10:12 PM
new.era.13's Avatar
new.era.13
i swapped the aftermarket bulb back with the oem bulb.
Old Aug 14, 2010 | 11:43 PM
JoeCombs's Avatar
JoeCombs
lol thats resourcefulness, nice.
NEWONE1
Feb 21, 2018 03:05 PM
wtfsajayte
Feb 21, 2014 07:09 AM
milellie11
Jun 28, 2011 03:21 PM
hung8852
Aug 27, 2007 03:05 PM
superpats
Lighting
Feb 1, 2006 03:30 PM
