New Product: VAIS Tech SL2iC
Old Dec 22, 2010 | 11:26 AM
  #196
rominl's Avatar
rominl
exclusive matchup
Originally Posted by viking880
I have the same question: Nav without Mark Levinson, would I benefit from ML+? Or is SL2IC good enough?
From what I understand, Mark Levinson systems have digital sound while without it, it's analog anyway. But there might be difference in the video?
Secondly, with ML+, if I don't care about using the Nav while driving, do I need the PS override? ML+ does allow screen usage while driving doesn't it?
Thanks in advance guys.
also, yes, there will be noticeable difference in the video quality as well with the ml+
Old Dec 22, 2010 | 11:28 AM
  #197
new.era.13's Avatar
new.era.13
Originally Posted by rominl
seems like you aren't really in the mp3 mode yet. might want to do the emulation again. make sure you hear all the beeps correctly
thats what i was thinking, but i done it over 4 times. Same results.
When i first installed it, i did CD-emulation, than changed it to CD-MP3 emulation. Does that effect the ipod out?
Plus my iphone 4 is on 4.1 firmware
Old Dec 22, 2010 | 11:38 AM
  #198
*Batman*'s Avatar
*Batman*
Is your phone connected via bluetooth? The programming process started by the beep won't happen if there is an active bluetooth connection.
Old Dec 22, 2010 | 11:48 AM
  #199
allst4r's Avatar
allst4r
can this show u ur iphone screen for example if im web browsing and uiseing goolge will i be able to see this on the screen ...
Old Dec 22, 2010 | 12:08 PM
  #200
new.era.13's Avatar
new.era.13
bluetooth is off. CD-MP3 emulation is programmed. Left switch down, Right switch up. One long beep than a short beep, than change switch up, one conformation beep, turn off the car, 10 seconds later, turn on, same situation.
pictures include.
Old Dec 22, 2010 | 12:23 PM
  #201
*Batman*'s Avatar
*Batman*
No idea. call vais tech support.
Old Dec 22, 2010 | 01:26 PM
  #202
new.era.13's Avatar
new.era.13
they told me that it might be my phone, but i tried both an iphone 4 and 3gs on 4.01 and 4.1 and still no luck.
when i first installed it, i did all the emulation. do you think messed it up? my dumbass, didnt read the manual correctly.
Old Dec 22, 2010 | 01:30 PM
  #203
rominl's Avatar
rominl
exclusive matchup
try the following:
- very quickly press the DISC button twice, it should cycle to your changer and then back to sl2ic. see if that helps. do this very quickly, like within a sec
- go to page 2, press on RETURN, and punch in the code to enable the video. by now your ipod should become available. see if you can play any videos, it should. if it works, touch the screen, go to page 2, and then press on RETURN button again. now you should be back to ipod. see if the screen comes up
Old Dec 22, 2010 | 01:32 PM
  #204
rominl's Avatar
rominl
exclusive matchup
no, not unless you jailbreak your iphone and install special software to fully enable video out from iphone. it's an apple problem
Old Dec 22, 2010 | 01:35 PM
  #205
rominl's Avatar
rominl
exclusive matchup
also try to go to FM, disconnect the phone, wait a bit, plug it back, and then go back to DISC (SL2iC) again, see if that helps
i am trying to think of all the possible combo
Old Dec 22, 2010 | 01:43 PM
  #206
*Batman*'s Avatar
*Batman*
The latest software is 4.2.1 That's what I'm running.
Old Dec 22, 2010 | 01:57 PM
  #207
HyperMKIV's Avatar
HyperMKIV
is anyone using this product with an iPad???
Old Dec 22, 2010 | 02:25 PM
  #208
*Batman*'s Avatar
*Batman*
You could, but it wouldn't change any of the features. It would be the same except for the fact that the iPad is connected.
I tested it with my iPad, iPhone and iPod touch. All work fine. But the iPod touch is the winner because it can be left in the car and be forgotten.
Old Dec 22, 2010 | 02:37 PM
  #209
*Batman*'s Avatar
*Batman*
Just posted a video to show how the ML Plus interface works on my review thread here.
ML Plus Review by Batman75
Old Dec 22, 2010 | 03:01 PM
  #210
HyperMKIV's Avatar
HyperMKIV
that's really good to know...!!!
thanks...
i'm debating about getting a touch just for this purpose...
maybe i'll steal one of my friend's ones... i'm sure someone has one tucked in a drawer somewhere...haha
