New Product: VAIS Tech SL2iC
in that case, i wonder if it's possible to rub a little usb hub close to the ML+, and then run two cables, one usb extension to the glove box flush mount if you want, and then another would be the ipod usb cable.
as long as you are conscious about which input is being utilized, and only one device (usb or ipod) is plugged in, i think it might work? i guess the question is whether the unit can handle a hub (which i suppose would draw a bit more power?)
Help
After reading all the latest posts and vaistech site info. on the 2 units, I'm really confused. I have Nav WITHOUT Mark Levinson , would I still notice a huge sound difference? I'm not sure if it would be worth the extra money for me. Should I get the SL2iC or the ML+ ?
confused
ed
After reading all the latest posts and vaistech site info. on the 2 units, I'm really confused. I have Nav WITHOUT Mark Levinson , would I still notice a huge sound difference? I'm not sure if it would be worth the extra money for me. Should I get the SL2iC or the ML+ ?confused
ed
From what I understand, Mark Levinson systems have digital sound while without it, it's analog anyway. But there might be difference in the video?
Secondly, with ML+, if I don't care about using the Nav while driving, do I need the PS override? ML+ does allow screen usage while driving doesn't it?
Thanks in advance guys.
I have the same question: Nav without Mark Levinson, would I benefit from ML+? Or is SL2IC good enough?
The ML+ sends a digital signal directly to head-unit, and the SL2iC sends analog signal from the iPod.
My guess is that even with the regular system, you will see sound advantage with the ML+ but it won't be as pronounced.
So if I was a non ML customer, I think it would boil down to this:
Trade-off for non-Mark Levinson customers for ML+
+ Slightly better sound
+ Much better menu and interface
- Loss of motion override for bluetooth and nav (can still use ipod out and video out in motion)
- Need to enter a 4 digit pin to override for video out
- Costs more
Obviously if you have the PS override kit, then the first two negs disappear.
If you have Mark Levinson then the sound difference is huge.
I can get to the screen that has the menu, play button, etc on the cd-mp3 emulation. I just cant get it to display my list of songs, artist, etc.
