There shopuld be a bundle of wires on the drivers side. I used it to run a wire for the autostart I put. Its tight but you could fit two or three more wires in the bundel. Ill see if i can take a pic tommor.
thanks alot, but are there any opening on your driver side. i'm trying to put a switch in by the coin holder
There's a grommet that you'll be able to see if you bend down and look at the driver's footwell area near the pedals. You can run your wires through there with a flathead screwdriver.
Javier
I guess theres no need for a pic thats the one I was telling you about.
