Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
- Lexus: How to Replace Your Dome Light
Step by step instructions for do-it-yourself repairs
LED Lighting Replacement Guide (w/Pics)
First of all, Kudos Brociouz, it's like a noob's wet dream. These are exactly what i needed to change my lighting. I checked SYLVANIA guide for bulb replacements, it's different than what you gave out tho, The SYLVANIA shows 579 or 3021 for front dome light, but you have 194 for front dome light. I am wondering are they the samething?
^ When Sylvania says "Dome Light" in their bulb guide, they mean the rear dome, which is indeed a 579/3021 31mm festoon bulb (just like in my guide). The front dome, however, is a 194/168 (same connector). Hope that clears things up!
^ You're welcome.
V-LEDS has apparently discontinued the 6000K version of the trunk light I originally recommended. Here's the 5000K version though: http://www.v-leds.com/Exterior-LED/C...00874-1-3.html Make sure you select the 31mm festoon base for it.
V-LEDS has apparently discontinued the 6000K version of the trunk light I originally recommended. Here's the 5000K version though: http://www.v-leds.com/Exterior-LED/C...00874-1-3.html Make sure you select the 31mm festoon base for it.^ You're welcome.
V-LEDS has apparently discontinued the 6000K version of the trunk light I originally recommended. Here's the 5000K version though: http://www.v-leds.com/Exterior-LED/C...00874-1-3.html Make sure you select the 31mm festoon base for it.The trunk is actually a 29mm festoon, so if you don't have that option and have to go with 31mm, you'll have to either hammer in the sides or modify the connector itself. Hammering is easier.
Great writeup up Bro! VLeds has a 4 hr 25% off coupon code "25FOR4" right now that expires at 4pm PST (7pm EST)
. With this, i just ordered a whole LED swap over my current LEDs which are no where near as bright, plus now they will all color match!
