Nav default?
Old Apr 23, 2010 | 02:54 PM
flektone's Avatar
flektone
Default Nav default?
Is there a way to change so when you first start up your car and hit "I agree" it will go to the audio screen instead of NAV? Also can I change it when I shift the car into reverse then back to drive the Audio screen will stay on instead of it going back to NAV? Basically I hardly every use NAV and just want to select it on my own when I want to use it. I dont want it popping up all the time.
Old Apr 23, 2010 | 08:08 PM
EJC's Avatar
EJC
You can change the settings so that the screen remains on the last setting without reverting back to Nav.
Check the menu settings on the Nav unit. I forget which button, probably menu. play around and you'll find it.
Old Apr 25, 2010 | 06:30 PM
flektone's Avatar
flektone
I found the option for audio so it stays on while driving. But my 2 questions does anyone know if its even possible? The most anoying one is when I put the car into reverse then into drive the NAV comes on. Is there a way to have it so when you do that it will go back to audio instead of NAV? Is that possible or does all your guys cars do that?
Old Apr 25, 2010 | 06:33 PM
tex2670's Avatar
tex2670
that's the only change you can make
Old Apr 25, 2010 | 07:42 PM
flektone's Avatar
flektone
which change?
Old Apr 26, 2010 | 04:22 AM
tex2670's Avatar
tex2670
which change?
That one.
Old Apr 26, 2010 | 04:58 AM
mikes rx's Avatar
mikes rx
I use "..." ....... a lot
Yeah, but i think that the system will function the way he wants after making that change.
My '10 nav system functions the way he wants. At startup, it's at whatever screen it was at before shutdown, and stays in whatever screen I select until I select something else or engage reverse.
And it reverts back to whichever screen it was in after shifting out of reverse.
Old Apr 26, 2010 | 08:32 AM
flektone's Avatar
flektone
hmmm, i swear ive been in almost every menu and cant find it. ill have to look further into this. maybe i can find it in the manual somewhere.
Old Apr 26, 2010 | 04:39 PM
tex2670's Avatar
tex2670
Info/ settings
Magellan
Aug 15, 2018 06:33 AM
ECL
Aug 21, 2015 07:57 PM
brickauto
GX - 1st Gen (2003-2009)
Aug 19, 2007 09:20 AM
Stevenicks
Feb 15, 2004 07:49 PM
