Will those wheels fit? START HERE.
Old Dec 14, 2011 | 10:19 AM
  #2896
projectdna's Avatar
projectdna
Originally Posted by jgonx213
im thinking of going 19x9.5 all around +22 offset
tires front: 225/35 and rear 245/35, will they fit even if im slammed?
Of course im going to roll and stretch
need answers quick! THANK YOU!
yes.
10char
Old Dec 14, 2011 | 10:35 AM
  #2897
jgonx213's Avatar
jgonx213
even if i go 10.5 in the rear?
Old Dec 14, 2011 | 11:05 AM
  #2898
projectdna's Avatar
projectdna
245/35-19 will stretch more on a 10.5 than 9.5.
Old Dec 14, 2011 | 05:40 PM
  #2899
Quik208's Avatar
Quik208
19x8. 19x10. 38/43. 235/35 265/30. Will those specs rub? Will probably be lowered on Megan coilover, not slammed but just get rid of some of the wheel gap.
Old Dec 14, 2011 | 06:46 PM
  #2900
SCWB's Avatar
SCWB
Originally Posted by A.C Milan
Some quick pics I took , sorry for the bad quality , still on the iphone3G
I know it badly needs a drop , just want to enjoy the "rubbing-less" ride for a while
Looks great! A.C. Just need a drop to finish the job.
Do you know what is the offset?
Old Dec 15, 2011 | 01:26 AM
  #2901
A.C Milan's Avatar
A.C Milan
Thanks! I'm looking for springs now.
Offset is +38 & +45
Old Dec 15, 2011 | 09:17 AM
  #2902
projectdna's Avatar
projectdna
highly unlikely.
Old Dec 15, 2011 | 12:56 PM
  #2903
509IS350's Avatar
509IS350
20x9+32 on 225/30/20 & 20x10.5+25 on 255/30/20 fit on is350. Rolling/shaving the rears. On h&rs for now
Old Dec 15, 2011 | 03:04 PM
  #2904
Mv350's Avatar
Mv350
you might need to roll the fronts with 20's and remove the front tab but itll work. roll/shave rears, either way
Old Dec 18, 2011 | 05:56 PM
  #2905
CarbonDtls's Avatar
CarbonDtls
Ok got 2 options for my rear wheels
255/40/18 is the tire with a 18x9 wheel
Offset is either 28 or 38
I am running 38 now with my other set of wheels but wondering if maybe I can run 28 safely.
I'm rolled in the rear and lowered with no finger gap. I never ever rub but would the 28 cause rubbing? I have adjustable arms in the back so I can dial more negative camber if needed.
so 28 or 38 what you think?
Old Dec 18, 2011 | 07:27 PM
  #2906
MoarLow's Avatar
MoarLow
I posted same question in aggressive wheel thread, apologize if I went to wrong thread.
On megan coilovers, thinking of 18x9.5 +22 and 18x10.5 +22 on 215/40 and 235/40 DWS with rolled fenders.
Let me know if this works without any camber mods or pulling!
Old Dec 18, 2011 | 08:13 PM
  #2907
bforbrian's Avatar
bforbrian
ET28 will be perfectly fine, especially for the rear.
Old Dec 18, 2011 | 08:15 PM
  #2908
bforbrian's Avatar
bforbrian
Highly suggest rolling and slightly pulling rear fenders. Not sure how the Conti DWS's stretch but some tires run narrow which helps with clearance. Some tires grab on to the rim of the wheel, posing some rubbing issues.
It also depends on how aggressively you are dropped. If you are slammed, then you might want to invest in camber kits. But you might be able to get away with those wheel and tire specs without an aggressive drop.
Old Dec 18, 2011 | 08:18 PM
  #2909
bforbrian's Avatar
bforbrian
Sounds like you're getting a set of Vossen CV3s.
I recommend a 35 series tire for the fronts, which, will be no problem but the rear will be difficult as it is also 20" in diameter.. so make sure you get a soft tire. Those sizes should work though.
Old Dec 18, 2011 | 11:21 PM
  #2910
projectdna's Avatar
projectdna
try 245/30-20.
will not work without fender mods, but will work without camber mods.
sidewall is relatively upright w/ a 255 on a 9"-wide wheel. you might be able to get away with it with more camber.
