Will those wheels fit? START HERE.
Old Nov 2, 2011 | 01:37 PM
  #2731
Mv350's Avatar
Mv350
Originally Posted by projectdna
+1. i should know.
lol ya that tire situation it's almost like i know what im jabbering about
Old Nov 2, 2011 | 01:39 PM
  #2732
Mv350's Avatar
Mv350
Originally Posted by airahcaz
Is there a catalog of all Lexus wheels from all models that will fit a 1998 GS 400 with no issues?
e.g. 2008 OEM Lexus GS 17's
or ES350 wheels
etc
Wheels that I cannot easily see, but can be shipped to me.. thanks
pretty much any lexus rim should fit on your GS, as long as you dont have the bigger brake calipers, im not sure what the 98 400 comes with
Old Nov 2, 2011 | 05:08 PM
  #2733
LexoticJ's Avatar
LexoticJ
Originally Posted by Mv350
he asked me in PM also, i said it should fit, but... he never mentioned his fenders were un modded. a 275 without rolled or shaved fenders is gunna be tight.
just so everyone knows, I ASSUME that if you dont say anything about no fenders mods, you either have them done already or ARE NOT AGAINST modifying your fenders...
to everyone
YOU NEED MODDED FENDERS FOR AGGRESSIVE WHEELS PERIOD
i have NO PROBLEM modifying my fenders if needed... thanks for your PM as it was much appreciated...
Old Nov 2, 2011 | 05:11 PM
  #2734
LexoticJ's Avatar
LexoticJ
i already addressed your fitment question, but since you made up your mind on a wider tire size, i see no point in giving more advice you won't take anyways.
and since you already went with those tires on those wheels, you'll just have to mount up the wheels and tires, and find out for yourself.
best of luck.
I went with a slightly wider tire due to the finding a matching set of tires at a good price through Discount Tire.... it was very hard to find a set of 265's with a matching set of 225's in the front and not compromise ride quality... my apologies if it offended you in anyway..
Old Nov 2, 2011 | 06:48 PM
  #2735
LexoticJ's Avatar
LexoticJ
this is what it's looking like on the rear for an update... yes I figured I will have to modify the rear fender...
Attached Thumbnails Will those wheels fit?  START HERE.-img_0310.jpg   Will those wheels fit?  START HERE.-img_0311.jpg   Will those wheels fit?  START HERE.-img_0312.jpg   Will those wheels fit?  START HERE.-img_0313.jpg   Will those wheels fit?  START HERE.-img_0314.jpg
Old Nov 2, 2011 | 07:25 PM
  #2736
JayDMiS's Avatar
JayDMiS
Well since i didn't get any specifics on my first attempt I'll try again. My question is, what would I have to do to fit my CV1s on my RWD IS250? 20x10.5 +25 and 20x9 +20 or this not possible?
Old Nov 3, 2011 | 07:59 AM
  #2737
projectdna's Avatar
projectdna
well, since you didn't include what your proposed ride height is (i'll assume you're willing to modify your fenders to make the wheels fit), i'll wait until you try again.
Old Nov 3, 2011 | 09:14 AM
  #2738
Mv350's Avatar
Mv350
you dont HAVE to run matching sets...
btw with that 275 is looks super clean either have them shaved or shave half and roll the rest and your set.
Old Nov 3, 2011 | 09:40 AM
  #2739
LexoticJ's Avatar
LexoticJ
Thanks bro. I'll keep you updates as I will have the full set on Friday and will post pictures
Old Nov 3, 2011 | 09:55 AM
  #2740
JayDMiS's Avatar
JayDMiS
Wow this amazing I'm new to this forum and I already ran into my first smarta$%. I apologize that my first question was lacking info. Can someone else answer my question?
Old Nov 3, 2011 | 10:39 AM
  #2741
projectdna's Avatar
projectdna
fyi, wheel fitment is different for oem ride height vs. lowered ride height, especially for wider wheels with "aggressive" offsets (your wheels fall into that category, btw).
that's why i "asked".
btw, try not to take an attempt at humor personally... and apology accepted.
Old Nov 3, 2011 | 07:24 PM
  #2742
dorkacho's Avatar
dorkacho
Default newbie question..
Can anyone please explain to me what offset does and how it contributes to your car? Does it just make your car look better by having the wheel mounted on further out away from center of the car? Sorry for the noob question,, and thanks in advance!
I'm debating to get 18 or 19, and I have a 350 dropped on H&R .. what would be a typical setup with good looks and handle?
Old Nov 3, 2011 | 08:35 PM
  #2743
LexoticJ's Avatar
LexoticJ
so I moved the car and let the rear settle a little on the 275/30-20 and this is what i got below... no rubbing noise any suggestions now that its settled? like shave roll? even when i put a passenger in the back it just tucked in more...let's get some positive answers since all the "INFO" is right here lol
Attached Thumbnails Will those wheels fit?  START HERE.-img_0322.jpg   Will those wheels fit?  START HERE.-img_0323.jpg   Will those wheels fit?  START HERE.-img_0324.jpg
Old Nov 3, 2011 | 10:33 PM
  #2744
projectdna's Avatar
projectdna
start here: this is tire rack's technical explanation of offset.
honestly, there's no template of what's the "best" diameter, width or offset for wheels. everyone will have a different opinion, so find out what you want first. not quite the definitive answer to your last question, but then again there isn't one.
best of luck.
if it's not rubbing, then what's the issue? please explain.
Old Nov 4, 2011 | 04:21 AM
  #2745
dorkacho's Avatar
dorkacho
best of luck.
Thanks! But I've read that before. But I just don't know where to start - do I pick the wheel width, then offset, then tire dimension? Everyone talks about offset but I just don't see how it comes into play. Is a more "aggressive" offset one that will look nicer, because it sits further out and make your car looks wider? Is that one of the main factors ? Thanks!!
