Steering Damper?
Old Feb 16, 2010 | 04:02 PM
IS250TW's Avatar
IS250TW
CL Folding 25,000
Default Steering Damper
As I've seen some owners overseas had installed the steering damper
Sewell Lexus provided the damper with the screws
http://is.sewellparts.com/accessorie...-2008-343.html
this is the link
what you need is the IS-F steering damper (Item No.45713-53020)
Another thing you need are two screws (Item No.90159-50199)
now since sewell sells the whole kit, just get the kit and everything needed will be in the package
step-by-step (For safety reasons, please disconnect the battery)
1-Take off the side covers of the steering column, shown in pic the side covers
courtesy of rcracer, can't find the pic so id have to borrow from you
no need to take off steering wheel, this pic is just to show where the cover is
2-Unscrew the Trox screw inside
3-Take off the airbag, disconnect the three wires were attached
4-Screw in the steering damper with the two screws that you bought with the damper
*Remember to relocate the wires under the little hook of the damper
put everything back together and you're done!
Everything can be done less than 15 mins.
Enjoy
Old Feb 16, 2010 | 05:21 PM
XhyDra's Avatar
XhyDra
Interesting.
In some way I solved the intermitent vibration coming from my steering wheel. I took the wheels off to clean them then put them back on and torqued them myself. I guess maybe for some reason they might have been over torqued by the tire shop.
Old Feb 18, 2010 | 08:12 PM
IS250TW's Avatar
IS250TW
CL Folding 25,000
Right, so I just ordered the IS-f steering damper from sewell parts
And I will keep this thread updated when I get the parts and install the damper
Old Feb 18, 2010 | 10:11 PM
xuningshen's Avatar
xuningshen
its just a weight right?
Old Feb 18, 2010 | 11:17 PM
IS250TW's Avatar
IS250TW
CL Folding 25,000
I heard it weight 230g
suppose to be something that make the steering more tighter and heavier
since it was standard in the is-f
its only twenty something dollars so i thought I'll just give it a try
Old Feb 18, 2010 | 11:27 PM
GiantsFan's Avatar
GiantsFan
^ wow cheaper than I thought it would be...
Old Feb 18, 2010 | 11:48 PM
XhyDra's Avatar
XhyDra
If you don't mind, can you post a link to the damper on Sewell's page.
Also please let us know exactly how it changes the steering and if it really dampens any vibration, I want this shtt!
Old Feb 19, 2010 | 02:52 AM
colecc's Avatar
colecc
How did u get the steering wheel cover off in the first place?
Old Feb 19, 2010 | 07:48 AM
IS250TW's Avatar
IS250TW
CL Folding 25,000
http://www.sewellpartsonline.com/***...l=224&year=170
this is the link for the is-f steering wheel figure, as you can see the part "45713A" is in the steering wheel instead of the isx50s which is not included
http://www.sewellpartsonline.com/***...l=208&year=168
besides of the damper, I also ordered the part 90159-50199 to make sure that i have the screw to screw into
as for taking off the cover
pop the side covers on the steering wheels and unscrew it
but make sure to unplug the battery to make sure that unplugging the airbag doesn't cause any accidents
and there are holes already drilled in the steering wheel so just plug and put the wires under the hook
tah-dah
but I heard its not necessary to unplug the airbag so....
I'll keep this updated =)
(Pics from http://forum.is250post.com/viewtopic.php?t=15956 )
It's in Chinese tho
Old Feb 19, 2010 | 08:33 AM
iSuxeL's Avatar
iSuxeL
This part is on eBay.
Old Feb 19, 2010 | 10:15 AM
DaSyce's Avatar
DaSyce
Does the counter weight really help with the steering wheel feel?
Old Feb 19, 2010 | 10:27 AM
XhyDra's Avatar
XhyDra
Nice write up,
thanks for the info. I'm ordering asap
I figure it should help with some vibration.
Any feedback?
Old Feb 19, 2010 | 10:29 AM
llamaboiz's Avatar
llamaboiz
ohh... nice affordable mod, see just when i think i'm done stuff like this keeps pulling me back in~
Old Feb 19, 2010 | 11:26 AM
XhyDra's Avatar
XhyDra
Ok order pending
let's hope it reduces some vibration.
Old Feb 19, 2010 | 05:10 PM
giantdefy's Avatar
giantdefy
wow, this may be a cool cheap mod to add to the car. Still waiting on more reviews before I do the mod!
