I noticed was that during at light stop, I could feel that the vibration through the steering wheel...felt a bit stronger. Do you guys think that if I change the steering damper will fix this issue ?
There are probably a ton of reviews already, but I figure one more wouldn't hurt.
I've had this installed for almost a year now, and after the first week or so, I pretty much forget I even did the mod. However, I've noticed that before I installed the steering damper, the bottom of edge of my hands would sometimes get numb from prolonged driving (e.g. NorCal to SoCal). After doing this mod, I cannot recall having that happen.
The torx bolts are under the small plastic panels on either side of the steering wheel. Look at the steering wheel from the side. The left side cover is about 2 inches wide by 3 inches tall that you need to remove with a small slotted screw driver. The right side is under the cover that surrounds the cruise control stick. Once you get it open, you'll see the torx head screws securing the airbag (one on each side).
