will this rub?
Old Feb 8, 2010 | 06:32 PM
joeker's Avatar
joeker
Default will this rub?
quick wheel fitment question...... will this setup rub on a no drop/moderate dropped 2is?
18x8+28 18x9+37
thanks
edit: 18x8+25, 18x9+25
Old Feb 8, 2010 | 08:40 PM
joeker's Avatar
joeker
i'm sure someone out there knows!!
Old Feb 8, 2010 | 09:18 PM
phongh's Avatar
phongh
nope. You will be fine.
just think of this. Most people run 19x8.5 22 front, 19x9.5 22 rear. and compare it.
The way i see it you can even go lower
Old Feb 8, 2010 | 10:55 PM
Signal_jp's Avatar
Signal_jp
also factor in tire size and suspension set up. we need more info
Old Feb 8, 2010 | 11:29 PM
Wierdazndu's Avatar
Wierdazndu
true. Anything wil rub if youre to low and tires are to big. More info pleeeaze. If youre conservative on drop and tire size you should be good without rubbing.
Old Feb 9, 2010 | 08:36 AM
Mv350's Avatar
Mv350
im rocking 18x8.5+27 w/ 225/40 in the front
18x9.5+30 w/ 245/40 rear no rub i had a slight rub when i had a 5mm spacer in the rear, could of rolled the fenders but i didnt wanna
Old Feb 13, 2010 | 04:38 PM
joeker's Avatar
joeker
so if i ran 18x8+25 with 225/40, and 18x9+25 with 245/40, on stock ride height, i should be fine no? .. sorry everyone, i'm a feel noob. my area of expertise is mobile audio
Old Feb 13, 2010 | 04:51 PM
rule1223's Avatar
rule1223
far from rubbing.
cuongiee
Suspension and Brakes
16
Mar 23, 2017 06:07 PM
InhumaneSC
May 27, 2011 07:27 PM
Vroomin350
Mar 28, 2011 08:40 PM
Joe C
Wheels, Tires & Brakes Forum
Nov 1, 2006 09:16 AM
TTurboPimp
Dec 20, 2005 07:49 AM
