Show me your alignment sheets
Old Jan 15, 2010 | 12:43 PM
gc86's Avatar
gc86
Default Show me your alignment sheets
I'm wondering what everyones caster is on the left and right front? I'm dealing with an insurance claim and I'm trying to get my car back to the way it was. Much appreciated people
Old Jan 16, 2010 | 04:01 AM
2slow's Avatar
2slow
Caster on our cars aren't adjustable, or to my knowledge.
The alignment machine i used didn't have a 2007 IS350, so i used the specs from a 2006. Toe was adjustable, but caster didn't have instructions on how to fix.
Old Jan 16, 2010 | 05:38 AM
ek9vboi's Avatar
ek9vboi
Caster is adjustable... well on the GS anyways, which shouldn't be much different from the IS.
Old Jan 16, 2010 | 09:50 AM
gc86's Avatar
gc86
Nah the only thing adjustable on the 2IS is toe, the caster/camber can somewhat be adjusted if you shift the crossmember. But most shops won't do that. I just want to know what the majority of 2IS' caster is at from the factory.
Old Jan 16, 2010 | 10:41 AM
projectdna's Avatar
projectdna
this thread has a few alignment sheets for your viewing pleasure:
https://www.clublexus.com/forums/sus...ight=alignment
hope this helps.
Old Jan 16, 2010 | 11:07 AM
gc86's Avatar
gc86
it helps a bit, thanks bro
Old Jan 16, 2010 | 12:19 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Sorry - this is NOT true at all. Camber and caster are both non-adjustable. If you have a serious caster issue, Lexus does offer alternative parts to make a small adjustment in either direction, but there are no adjustment cams for caster or camber on any 2IS including IS-F.
Old Jan 16, 2010 | 02:32 PM
2slow's Avatar
2slow
To fix some of my issues with alignment i put my car onto a rack, loosened all bolts for the rear suspension and jacked up the 2 rear tires separately until i reached ride height. Then i tightened them down. Same for the front. Put it on the alignment rack. It took off a few degrees which was well worth it.
Old Jan 16, 2010 | 06:15 PM
ek9vboi's Avatar
ek9vboi
Hum... after reading a few of the posts in this thread, makes me think of what they did to my car now. I did get a "special" alignment since my toe was really out in the front from being so much lower.
Old Jan 16, 2010 | 07:15 PM
2slow's Avatar
2slow
^Toe is adjustable.
Old Jan 19, 2010 | 12:25 PM
sailing217's Avatar
sailing217
I just got new struts and alignment. Sorry but I threw the measurements away.
Camber/caster is not adjustable. (lobuxracer is correct about lexus can do very small adjustments with other parts)
Toe is.
Set to stock there is a slight toe-in I'm told. I'm taking it back to get the front dead straight as above 80mph it gets twitchy. Doesn't pull left or right, just twitchy. Mechanic said he'll set so no toe at all and go dead straight.
Took awhile for my Eibach springs to fully settle and really go toe out. One wheel was 1.38 degrees out.
seanmwple
Oct 10, 2017 08:18 AM
JM51526
IS F (2008-2014)
Jun 30, 2014 09:16 AM
MashinA
Suspension and Brakes
24
Mar 14, 2011 12:35 AM
blueridge
RX - 1st Gen (1999-2003)
Aug 27, 2009 01:52 PM
guod
CL of Southern California
Aug 18, 2009 04:35 PM
