talk to miik350.. he had the same issue.. everytime the body would flex there would be a creaking noise.. i was there when he brought it into the dealer for that service
I have a clattering sound near my moon roof behind the drivers head. I've pin pointed it to some mechanical arm that bounces up and down and bumps hitting the sheet metal of the roof.
I usually close the shade when it does that and it becomes far less noticeable. I should probably tell them about it but I feel as though I've already complained toooo much about squeeks and rattles.
by bringing it to the dealer.. warranty should cover it. if you don't have your warranty anymore you might want to do the vaseline thing.. no idea if that works though, but its worth a try
What exactly did he state in his complaint? I am under warranty
Two times, I've had a loud cracking sound coming from the roof when going diagonal up a steep driveway. Certainly the car was twisting when it happened, but it shouldn't be happening in the first place. Either way, no glass broke and it hasn't done it for almost a year now. I do not advise throwing lubricant all over the place. As someone mentioned, it can break down the rubber and it also causes dirt and dust to stick, which creates further problems.
