Cutting Fender Procedures
Old Oct 2, 2009 | 09:26 PM
jnguyen87's Avatar
jnguyen87
Default Cutting Fender Procedures
So im tired of rubbing my rear wheels on my fender. I want to cut my fenders myself and ive heard its a pretty easy job. So guys what are the exact procedures and tools needed to do this job? Just take a dremel to it?
Old Oct 3, 2009 | 05:28 AM
passnu2's Avatar
passnu2
I dont suggest that you do this if you have never done it before. Its not a hard or long process but have a local member help or pay a shop to do it.
Old Oct 3, 2009 | 06:38 AM
Robs IS250's Avatar
Robs IS250
searching is your BFF
Rolling VS Cutting
Old Oct 3, 2009 | 09:33 AM
xuningshen's Avatar
xuningshen
theres always a first time for everything!
Old Oct 3, 2009 | 09:48 AM
masagsxr's Avatar
masagsxr
tape the outside fender well/quarter panel as a precaution then cut or roll the lip.... Good luck.
Old Oct 3, 2009 | 10:47 AM
jnguyen87's Avatar
jnguyen87
Yea ive read that thread before. I just wanted someone thats done it have some kinda procedure or tips for me. I mean do you just take off the wheel and go to town on the fender with a dremel? Do you have to heat it up or anything? Thanks for any input guys.
Rolling VS Cutting
Old Oct 3, 2009 | 10:54 AM
Robs IS250's Avatar
Robs IS250
Heating is recommended even though i didn't do it...
Old Oct 3, 2009 | 10:56 AM
masagsxr's Avatar
masagsxr
If you are cutting it, no need for heat gun. Heat gun is when you roll the fender. It helps avoid paint from cracking but still 90% chance that the paint will crack.... The reason you would want to take the wheel off is just so that you have room to work on it. If you are comfortable cutting it without taking the wheels off then by all means go for it.
Old Oct 3, 2009 | 02:28 PM
iSuxeL's Avatar
iSuxeL
If you're Viet and you do nails, this will be cake
Old Oct 3, 2009 | 02:31 PM
iSuxeL's Avatar
iSuxeL
Why am I repeating myself? LOL use these and you will fine.
Attached to one of these:
And used a cutting wheel like this:
Then sanded smooth with this:
And finished off with rust enamel in flat black like this:
Old Oct 3, 2009 | 02:41 PM
EN_VY's Avatar
EN_VY
Cutting wont chip the paint?? I took mine to get it cut to a tire shop. They put tape on it and so, when they where done I went to inspect, and the paint was chipped!! It was from the inside though. It has now gotten to being almost visible.
antbo
CL of Southern California
418
Jul 12, 2018 04:43 PM
bfg23
Dec 31, 2014 11:32 AM
Whitena
Feb 5, 2013 11:44 AM
SorrGwa
Sep 26, 2009 01:22 PM
moo_juice
Jun 27, 2009 01:52 PM
