Maintenance menu on 2010 IS 350??
Old 09-23-09, 01:02 AM
altapowder
altapowder's Avatar
Default Maintenance menu on 2010 IS 350??
Does anyone have any idea how to get into the maintenance menu on the new 2010 IS 350?
I would like to modify the settings so the phone buttons stay on while I am driving.
I personally think it is more dangerous to have the phone functions disabled while I am driving. When they are disabled it means I have to pick up the phone to dial a phone number instead of dialing it off of the display.
Kind of dangerous safety feature...
Old 09-23-09, 01:46 AM
joeker
joeker's Avatar
uhh.. cant you just press the dial button on the steering wheel?
Old 09-23-09, 05:52 AM
vdubturbo
vdubturbo's Avatar
or program the speed dial? You can use that at any speed.
Old 09-23-09, 06:36 AM
tex2670
tex2670's Avatar
It's a bit more complicated than that:
https://www.clublexus.com/forums/is-...en-moving.html
Old 09-23-09, 08:54 AM
dojoman
dojoman's Avatar
I'm not sure if the voice commands from 06-09 still works on '10 but just press voice command button on steering wheel and say "dial by number" then say the number after the tone.
Old 09-24-09, 11:37 PM
altapowder
altapowder's Avatar
I could do that, but I like to use the touch screen. I also want to play with some of the settings in the maintenance menu.
Old 09-25-09, 04:08 AM
Bichon
Super Moderator
Bichon's Avatar
The nannies that prevent you from using the system while the car is in motion cannot be disabled from the maintenance menu.
If you want to get into the menu for another reason, such as adjusting the sensitivity of the bluetooth menu, here is how to do it. With the car on and in PARK, hold the INFO button depressed while at the same time quickly switching the light stalk between OFF and PARKING LIGHTS (about half a dozen times) until the maintenance menu comes up.
rstanleyb
LS - 5th Gen (2018-present)
12-04-18 02:30 PM
Nikaes350
ES - 5th Gen (2007-2012)
09-25-18 06:26 AM
lexusrich
RX - 4th Gen (2016-2022)
07-24-16 01:14 PM
swtsae
RX - 3rd Gen (2010-2015)
12-26-09 06:44 PM
Quick Reply: Maintenance menu on 2010 IS 350??
