Question about d4s bulb failure
Old Aug 26, 2009 | 08:01 AM
EyeKutr's Avatar
EyeKutr
Default Question about d4s bulb failure
Hey 2IS crew
I posted this in lighting and got no answers.....I am posting it here because the Is has same lighthing setup and there are so many more IS cars that there should be more experience with this here in the IS forum.....
I have an 06 gs300 with oem HIDs, d4s bulbs. Car has 54k miles and tonight I noticed a bulb was out.....turned the lights off and back on, light is back on....is this the way HIDs behave before going out ??? I know halogen filament bulbs burn out and they are done...what do HIDs do? I realize I could swap bulb from one side to the other and help pinpoint bulb vs ballast issue but common things occur commonly....any thoughts ?? Thanks
Old Aug 26, 2009 | 08:17 AM
SD.IS's Avatar
SD.IS
does it flicker before it turns off?
Old Aug 26, 2009 | 08:28 AM
EyeKutr's Avatar
EyeKutr
YOu know it was just near sunset and I could not see the lights on the road yet...so when I came home I noticed it was out when I got out of the car. This morning I drove with them on to work and they both worked (20 min drive).
Old Aug 26, 2009 | 08:42 AM
SD.IS's Avatar
SD.IS
next time when you get a chance to drive at night, watch out for it. or easiest way to pinpoint it is as you stated with the bulb switching. that will save you time. if its the bulb at least you'll have a heads up to get new bulbs while your current ones are slowly dieing.
my passenger side bulb flickered then turned off. now i have garax 8k's and its
Old Aug 26, 2009 | 08:49 AM
EyeKutr's Avatar
EyeKutr
Thank you for the reply, I have been thinking of getting Garax 6k d4s bulbs and found a vendor and with a coupon code is like $85 a set....but if I am having a ballast issue, I would almost think of swapping to d2s ballasts and 6k ultinon bulbs.....crazy but I may do it....
Old Aug 26, 2009 | 09:10 AM
SD.IS's Avatar
SD.IS
if its still under warranty why not just take it into the factory? i got my garax from ebay for 80 shipped +1 year warranty
Old Aug 26, 2009 | 10:08 AM
EyeKutr's Avatar
EyeKutr
my car was initially purchased in 03/05 and has 56k on the odometer....I guess I could say it has intermittent issues but either way it is probably not covered anymore...
ThatGuy415
Lighting
Mar 13, 2011 09:03 PM
Jsy622
Oct 1, 2009 09:38 PM
cm09578
Sep 22, 2009 11:01 AM
retrodrive
Lighting
Mar 6, 2003 10:10 AM
