Another AWD setup question
Old Jul 15, 2009 | 02:26 PM
soleeasii's Avatar
soleeasii
Default Another AWD setup question
will this setup work on AWD, without modification to the fenders?
19x9.0 +35
19.9.0 +25
I'm already dropped on BCR Coilovers too!!!
Old Jul 15, 2009 | 05:00 PM
love67's Avatar
love67
depend on how low are you going to drop... and the tires size..
im rubbing the front inner fender wtih 19x8.5 +36 with 235/35/19 tires....btw i still have 1/2 to 1 finger gap...
and the rear should be fine.....
Old Jul 16, 2009 | 12:09 AM
soleeasii's Avatar
soleeasii
my second option is, 19x8.5 +40 (f) with a 235-35-19 tire and 19x10 +45(r) 265-30-19 tire... I don't mind using a spacer.. Is this possible without fender modification and without straining the AWD?
Old Jul 16, 2009 | 07:43 AM
laobo979's Avatar
laobo979
both set up would work but for your 1st choice with the +25 i pretty sure you going to have to mod your fender. on your 2nd setup you be good but go with +35 front and +30 rear and you wont need spacer and no fender mods
Old Jul 16, 2009 | 02:14 PM
soleeasii's Avatar
soleeasii
So my second setup won't affect awd? I read somewhere about the diameters needing to be the same....
Old Jul 16, 2009 | 03:28 PM
niteLEX's Avatar
niteLEX
that is ur best bet....you can go staggered but its "recommended" to go same size all around. 9in in the front might be to wide....8.5 should work for sure.
Old Jul 16, 2009 | 10:28 PM
soleeasii's Avatar
soleeasii
when using the tire calculator.. am I comparing the stock size to the aftermarket size, or am i comparing the aftermarket front tire size to the aftermarket rear tire size? and exacatly what am i looking at...
Old Jul 16, 2009 | 11:24 PM
love67's Avatar
love67
comparing front and rear, the best set up is 235/35/19 and 275/30/19
Old Jul 17, 2009 | 06:36 AM
soleeasii's Avatar
soleeasii
is it safe to run on 235-35-19 and 265-30-19 though??
Old Jul 17, 2009 | 12:57 PM
love67's Avatar
love67
well...there is 0.2" off comparing to the front and rear.....if you really want this set up, yes you will be fine...
but if you "just" want the 235...then you better get 275...because it's like no off....so 235 and 275 is the best....which it's safer...
or if you just want the 265, then go with 225/35/19...again it's only like0.1" off...it's still better than the set up that you want.
but again...your set up is still fine.
Old Jul 17, 2009 | 09:13 PM
laobo979's Avatar
laobo979
your safe im running those size tire and itz all good
MX5
Apr 22, 2013 02:49 PM
lexus316
Mar 18, 2012 06:30 PM
H-I-M
Jan 31, 2011 06:42 AM
Mrbanhbao
Oct 19, 2010 02:32 AM
