I needed new tires installed on my GX 460, I called around and was surprised what it was going to cost to mount, install new TPMS's and balance. My local Lexus dealer (almost an hour away) was so high I am convinced they did not understand what I wanted. So I went to Walmart and they installed the 5 new tires, balanced them and installed the new sensors. All for less than a hundred bucks. They appear to have done a great job.
Problem now is programming. Walmart said prior to starting they doubted they could program them and they were correct. 4 tires show the correct 36 PSI. One showed 6 PSI when tire held 36. After driving for an hour it shows 22 PSI while the tire has 36 in it. SO, I either have a bad sensor (these were new genuine Toyota sensors) or the programming is off. Has anyone had any luck with Carista
I think the trick is to buy the TPMS sensors that are direct replacements (i.e. same part number and brand or OEM equivalent). From what I understand, in that case, you just add the sensors to the car's TPMS ECU, and there is no "programming" -- any tire shop can do this. If the parts you got are not compatible, you will run into problems. You should confirm you got the right parts.
