Something that make me concern tonight!
Old May 18, 2009 | 09:13 PM
EthanV's Avatar
EthanV
Unhappy Something that make me concern tonight!
I was at my friend's house today. I wanted him to here the engine so I floored it all the way (car was parked)and the redlight on the tach odormeter was came up. Normally when I drive I only see it lights up orange. I floor several time but only once it show up the red ring and after it I didnt do it anymore...Is it normal or I got it too much pressure??? Is it gonna hurts the engine???
Old May 18, 2009 | 09:16 PM
chris07is's Avatar
chris07is
not really...well im not quite sure...6500 RPM is the rev limiter...thats were red tach turn into ..
Old May 18, 2009 | 09:19 PM
EthanV's Avatar
EthanV
So I didn't harm the engine?...Can some one confirm...I think 6400rpm is the red line.
Old May 18, 2009 | 09:29 PM
YooNiBaLL's Avatar
YooNiBaLL
as long as you didn't go into the redline itself, i think you'll be fine. the red light comes on before the actual redline to warn i think but i may be wrong. just don't do it again.
Old May 18, 2009 | 09:34 PM
acefalcon2's Avatar
acefalcon2
never redline this thing... seen engines blow before.. but not on IS.... my friend used to floor and redline quite a few times.. and once he blew a Audi TT engine
Old May 18, 2009 | 09:36 PM
EthanV's Avatar
EthanV
So you are not sure either?
Old May 18, 2009 | 10:55 PM
Nellyhx's Avatar
Nellyhx
I dont know how bad it is for our engines but ive done it a few times, my car's still fine. Just don't do it often
Old May 18, 2009 | 11:02 PM
jc86's Avatar
jc86
it is bad to a degree.. just don't have too much fun doing that while you are in park and you just started your engine.. it's less damaging if you've riving for a while
Old May 18, 2009 | 11:04 PM
Yiujai86's Avatar
Yiujai86
CL Folding 25,000
I read somewhere that redlining your vehicle in neutral is worse than redlining while you are driving. If someone can come in here and clarify this.
Either way, it can't be good because the vehicle come with a rev limiter. In fact, i cant even redline my TL because it would shift for me right before redline or not go over 4k rpm in neutral.
I've redlined the ES before on accident but the car runs fine. Done worry too much and just dont do it again.
Old May 18, 2009 | 11:34 PM
projectdna's Avatar
projectdna
the light ring lights up and changes color at different RPMs. think of it as a "shift light".
as even the most well-built engines can withstand only so many full-throttle redline pulls, doing that accelerates engine wear and tear to the point that you might end up with premature engine failure.
Old May 19, 2009 | 07:27 AM
EthanV's Avatar
EthanV
I did drove like 7 miles before I got to his house..
It was parked like 2 minutes than I turned it on..The red ring only shown once and I didn't do it again.
Old May 19, 2009 | 07:32 AM
IS-SV's Avatar
IS-SV
Somewhat abusive to engine, but no harm done. Check manual as to how you can set "warning orange/red rings" for speedo and tach.
nuraman00
Aug 20, 2018 08:26 AM
Sektatasek
Sep 18, 2012 06:16 AM
k2sty1
May 18, 2010 04:41 AM
04lrg
Mar 12, 2007 09:44 AM
acl15
Apr 19, 2006 06:00 PM
