TPMS error message (!)
Old Apr 8, 2009 | 03:21 PM
andyboy's Avatar
andyboy
Default TPMS error message (!)
I swapped out my wheels with my girlfriends wheels. We both have a AWD IS250 and since I'm selling my car my girl wanted my wheels. We just did a simple swap and now her TPMS is going off. I'm going to assume this is b/c of a new Senor ID that had not been registered to the car yet. I ran through the steps in initializing the sensor through < ON/OFF > option and held the < ON/OFF > button for over three seconds...it registered ok but still has the error (!)
Do I need to get this registered at Lexus? Am I missing something else? Tire's have been inflated well enough.
Old Apr 8, 2009 | 03:28 PM
acefalcon2's Avatar
acefalcon2
the registration is done in lexus dealerships where they use their computers to program each of the codes into the car..... initializing it... i think is only to swap between main and 2nd..
Old Apr 8, 2009 | 03:40 PM
andyboy's Avatar
andyboy
There's gotta be a way to find the register code for each sensor without unmounting the tire correct? Is this written somewhere when you buy the car????
Old Apr 8, 2009 | 03:43 PM
Evil Teo's Avatar
Evil Teo
check wit lexus as they should have ur code or u will need to unmount.
Old Apr 8, 2009 | 04:27 PM
as3.0cl's Avatar
as3.0cl
lexus may have the coes for your original wheels. they have tool that can reed the sensors, what happens is they push the pin in the stem down releasing the air from the tire, at the same time a tool they have scans the monitor and a code that is associated will come up.
they overrode my main set by accident and didn't have the codes when i bought the car. the tech was nice enough to come to my house where my stocks where to get the codes off of the stock sensors and program them into my car right in my garage.
Old Apr 8, 2009 | 08:04 PM
ISBU's Avatar
ISBU
The dealer should have a tool to read the serial numbers of the tpms without unmounting the tires. Then they can program it to the car's tpms ecu.
Old Apr 8, 2009 | 08:44 PM
acefalcon2's Avatar
acefalcon2
the dealers are the ones who have those things other than that... you have to unmount it... and yeah... $$$$ kaching kaching... go to the dealer... i am having mine programmed for free
Old Apr 8, 2009 | 11:30 PM
istundra's Avatar
istundra
actually... my mechanic has a tool that scans for code.... hm..... haven't seen it in action tho... Yes, you will have to swap sensors or get it reprogrammed.
Old Apr 9, 2009 | 12:10 AM
Joe Z's Avatar
Joe Z
The Lexus / Toyota Techstream laptops can pull the codes from each car.
You can than swap the TMPS Sensor ID's for both cars.. Just need that laptop from a dealership tech and some pen & paper..
Eventually, the TPMS light in your car is going to go off as well..
Joe Z
PDizz
Wheels, Tires & Brakes Forum
Oct 6, 2017 04:41 AM
Lmood
IS F (2008-2014)
16
Oct 21, 2014 03:48 PM
thomastan
Mar 19, 2009 01:21 PM
WhitBaby
Oct 10, 2008 10:45 AM
