Low tire pressure
Old Apr 4, 2009 | 11:16 PM
VTLexus's Avatar
VTLexus
Default Low tire pressure
Is it common for the tire pressure to decrease to the point that the light comes on over the course of a few weeks, generally induced by colder weather? The car was garaged (and not driven) for the past 3.5 weeks and the light came on when i had just filled the air before leaving town.
I just want to know if this is normal or if i probably have a leak. also, this only seems to happen to the rear tires (one or the other, just depends). will the dealer fix it if it's a leak?
Old Apr 4, 2009 | 11:19 PM
wolverine's Avatar
wolverine
not normal check for nails
Old Apr 4, 2009 | 11:47 PM
GiantsFan's Avatar
GiantsFan
This has happened to me before.
I just filled it up and the light never has come on since....
Old Apr 5, 2009 | 07:19 AM
Sh0gunkid's Avatar
Sh0gunkid
drastic change of temperature can definately affect the air in your tires. fill it up again, and check in a couple hours and see what happens. if your light comes on again, then most likely you have a leak somewhere.
Old Apr 5, 2009 | 09:38 AM
VTLexus's Avatar
VTLexus
well this has been happening for a few months now, not a one time issue. i'll fill it up, and after a few weeks, esp if i dont drive the car for a day or two, the tire pressure drops and the light comes on. seems like it's not normal, i'll see if i can find a nail or something
Old Apr 5, 2009 | 09:42 AM
Phil888's Avatar
Phil888
Well it all depends on what kind of wheels you're on. Aftermarket wheels? Cause if you have a three piece wheels its mostly likely to leak, just like mines. If I let it sit for a week or so I notice the psi drops crazy. But if you're on stock its probably you need a new set of wheels if they're worn out. Many possiblities, but just fill it up and see where it stands.
Old Apr 5, 2009 | 09:45 AM
VTLexus's Avatar
VTLexus
stock wheels, and i have 13k miles on the car. it'll be fine if i fill it up, for 2-3 weeks.
Old Apr 5, 2009 | 01:53 PM
NeverSatisfied's Avatar
NeverSatisfied
Same here. All of a sudden, the low pressure light comes on. I'm thinking great... gotta buy a new tire cause of a nail in the rubberband tires. Filled it up twice and it never happened again!
Old Apr 5, 2009 | 02:05 PM
javyLSU's Avatar
javyLSU
2IS OG
Phil, I've seen you post this a few times... 3 piece wheels aren't SUPPOSED to leak just because they're 3 piece wheels. If they're leaking, something is wrong with them, and you should get them checked out and fixed.
Javier
Old Apr 7, 2009 | 09:27 AM
fredw1's Avatar
fredw1
Every year, my TPMS light comes on at the start of cold weather. I just add a few pounds of pressure and it's OK until the next year.
Old Apr 7, 2009 | 10:47 AM
blk250's Avatar
blk250
got it couple times, but did not come on again...
check for nails bro..
Old Apr 7, 2009 | 11:25 AM
curtdragon's Avatar
curtdragon
CL Folding 100,000
Not necessarily nails. My G20 had an issue with the stock rims. they bent easily and the tire would have a slow leak.. it is possible that is the case.. check for damage on the rim both on the inside and outside lip
Old Apr 7, 2009 | 07:11 PM
VTLexus's Avatar
VTLexus
thanks for the help guys, got it chekced out today and it was a small screw.
Huskers 22
Oct 31, 2019 05:02 PM
Tiffanyly
RX - 4th Gen (2016-2022)
Mar 24, 2019 02:05 PM
Wronglane
GX - 1st Gen (2003-2009)
19
Feb 28, 2014 06:50 AM
quadocox
Jan 9, 2008 12:56 PM
sidgriggs
Sep 21, 2006 08:17 AM
