I have two random questions ?
Old May 14, 2008 | 06:03 PM
HKS350's Avatar
HKS350
Default I have two random questions ?
These are in no way related so, sorry.
#1 How do you remove the rear bumper reflectors? The ones right above the exhaust. Do they snap in/out or bolted?
#2 I just filled up to ol' Lex (btw $60 ouch) and was reading the new label on the pumps. It stated that the ethanol-blended precent was a mix with 15%. When did this change from 10%? And how does this change the combustion process and still maintain 93 octane? Wouldn't this fuel be more stable? Could I run mid-grade with such a blend?
These are my two question that turned into 5. Please point me in the right direction.
Old May 14, 2008 | 06:17 PM
isthrizzy's Avatar
isthrizzy
In all the posts I've read, you need to remove the bumper to get the reflectors out.
Old May 14, 2008 | 06:39 PM
HKS350's Avatar
HKS350
That sucks ^^^^^ Now I must labor over these.
Old May 14, 2008 | 06:50 PM
slee18's Avatar
slee18
what are you thinking of doing?
Old May 14, 2008 | 06:55 PM
llamaboiz's Avatar
llamaboiz
from 10% to 15% eth??? well that means a bigger -% hit to your mileage
Old May 14, 2008 | 07:05 PM
DRivera250's Avatar
DRivera250
you could just black out the reflectors.
Old May 14, 2008 | 07:32 PM
meefer's Avatar
meefer
Plenty of people make pre-cut vinyls for the reflectors.
The ethanol% going up means a hit to your mileage, but that's about it I think.
Old May 14, 2008 | 08:43 PM
smokyis350's Avatar
smokyis350
i blacked out my reflectors with a vinyl.
it still shows red during the day time. but when it is dark, its not noticeable
Old May 15, 2008 | 05:58 AM
rdgdawg's Avatar
rdgdawg
Yeppppppppppppp... but % should be going DOWN with summer approaching... if I'm not mistaken...
Old May 15, 2008 | 06:42 AM
Brian231's Avatar
Brian231
Ethanol corrodes iron parts slightly. I wish they did not even add this to fuel, but it is a cost and environmental issue. As for the bumper reflectrs, removing the rear bumper skin is not too labot intensive. When it comes time fo rme to have mine repainted, I am going to remove those reflectors and bondo the holes.
Old May 15, 2008 | 01:27 PM
HKS350's Avatar
HKS350
For the bumper reflectors - I going to have them painted with my chrome grill trim ring next week. I'm color matching. GFM....
As for the Ethanol increase - From what I've read oil companies started adding ethanol to fuel when they removed leaded gas from the market. The fuel lost some of its stabaillty and ethanol was the cure. But does the higher % mean more stable? I've also read that they increase the % when the oil companies dilute the fuel with water. Does the higher% mean I'm getting screwed, more so than I thought?
Old May 15, 2008 | 06:37 PM
passnu2's Avatar
passnu2
I havent seen any changes at the pumps here with the exception of the price increase. I will have to look next time. all the pumps are 10% in IL that I am aware of.
I just got the overlay myself. havent installed but it looks better. i would rather fill them in but i dont want to waste the $$$ as good as it would look
Old May 15, 2008 | 09:36 PM
mikes rx's Avatar
mikes rx
I use "..." ....... a lot
You better post pics
Old May 16, 2008 | 06:39 AM
Kurtz's Avatar
Kurtz
Lead was removed from gasoline (in the US anyway) decades ago at this point.... what ethanol IS commonly replacing these days is MTBE, which was found to pollute ground water...and MTBE is what commonly replaced lead in gasoline back in the 70s.
nulex1
Dec 11, 2016 04:17 PM
LiLS
IS F (2008-2014)
23
Aug 21, 2016 03:01 AM
myonoshane
Jun 7, 2015 07:40 PM
Smoky350
May 17, 2007 08:35 AM
SC3005SPD1
Jun 8, 2005 03:21 PM
