Front Fog Lights being REALLY Hot.
Old Feb 10, 2008 | 07:10 PM
loftus112's Avatar
loftus112
Anyone have more takes on this topic?
Old Feb 10, 2008 | 08:59 PM
carchitect's Avatar
carchitect
I too thought the OEM bulbs get the housings too hot. With a temp gun I measured the temp of the low beam (OEM HID) and they were at 95 deg F and the fogs were at 125 deg F. This was when the vehicle was driven for 45mins in 40 deg F ambient temp so in summer it would definitely get a lot warmer. Glad I switched to 3000K HID fogs instead. Now they both are at a cool 95 deg F.
Old Feb 10, 2008 | 09:24 PM
4TehNguyen's Avatar
4TehNguyen
they are halogen bulbs, they get hot
Old Feb 11, 2008 | 09:01 AM
Brian231's Avatar
Brian231
I have not heard this with aftermarket HID kits, but I have heard of fires and harness meltdowns with those cheap aftermarket higher wattage Non-HID bulbs.
Old Feb 11, 2008 | 09:04 AM
kiddolay's Avatar
kiddolay
Default Fog Overlay
Will the stock fogs burn up the Yellow fog Vinyl?
Old Feb 11, 2008 | 09:43 AM
Doushiyou's Avatar
Doushiyou
thats what i was thinking. Ill be swapping to HID.
Old Feb 11, 2008 | 07:51 PM
loftus112's Avatar
loftus112
Nope. Although it (non-HID fogs) gets extremely hot, my blue vinyl overlays look fine.
Old Feb 12, 2008 | 02:03 PM
kiddolay's Avatar
kiddolay
HIDs on Fogs really worth it? (Parts + Labor)? Are they much brighter? I want to go for the 1IS look with yellow fogs. I am planning on yellow overlays and JDM yellow fogs. If anyone has suggestion, please let me know.
I don't mean to hijack the thread.
Old Feb 12, 2008 | 02:30 PM
Brian231's Avatar
Brian231
This is exactly what I did, HID will always be brighter, but I didn't want that to overpower my lowbeams. I put Yellow same wattage 55w yellow bulbs and it was not yellow enough. Basically a step up from the cream oem bulbs. I then bought the Rvinyl protective kit that is yellow and it is fine. Plus, it protect the lense from rock chips. use the code"Rvinyl" (case sensitive) at checkout. It will not melt either.
Old Feb 12, 2008 | 02:45 PM
almacruel's Avatar
almacruel
Originally Posted by M1sTa801
yes it gets VERY VERY HOT while installing my HID fogs i turned it on for 15 secs touched the bulb and it burnt me! luckily theres carpet in my garage i could have broke the bulb when i dropped it :/ lol
Correct me if I'm wrong but aren't you not suppose to touch the HID bulbs with your fingers because the oil on you fingers ruin the bulb and make it have a shorter life span...
Es300Lover
23
Nov 21, 2013 12:43 PM
AlohaCab
CT 200h Model (2011-2017)
Feb 13, 2013 03:27 PM
za3879
Lighting
Nov 1, 2004 10:09 PM
krnchingu
Lighting
Oct 22, 2002 02:29 PM
Legends6spd
Mar 4, 2002 02:40 PM
