Fog light watts question
Old Oct 13, 2007 | 06:53 PM
andyroo's Avatar
andyroo
Default Fog light watts question
Hey, I just installed nokya 8500k 80w bulbs on my fog lights for my car and was wonderin if I should take them off because I've been readin that its bad to have such high wattage? Thanks.
Old Oct 13, 2007 | 09:07 PM
PNice972's Avatar
PNice972
it can melt the harness if the watts are rated higher than the oem bulb. it happened to my accord. even with a power adaptor that piggy backs off the battery to give it more juice, it still melted.
Old Oct 13, 2007 | 09:39 PM
llamaboiz's Avatar
llamaboiz
My Nokya 2500k are 70w and i've had no problems and i'm not willing to plug in nething higher.
Old Oct 13, 2007 | 10:07 PM
Tangerine's Avatar
Tangerine
Lexus (as well as other higher end vehicles) has a higher tolerance for heat/current in the wires they use. For the piece of mind I wouldn't. If you don't want to take them out just don't use them that much.
Old Oct 29, 2007 | 08:46 AM
inwood's Avatar
inwood
Does anyone know the actual wattage for the 2is oem fogs?
Old Oct 29, 2007 | 09:05 AM
inwood's Avatar
inwood
Also, im looking at a set of 2500k halogens w/ a draw of 55W & output of 150W. Will this be of any concern for me regarding the high wattage output (ie will it melt the harness)?
Old Oct 29, 2007 | 09:11 AM
Kurtz's Avatar
Kurtz
IIRC stock fogs are 55W
Old Oct 29, 2007 | 11:15 AM
T4styPh0's Avatar
T4styPh0
You should be fine with that. What they mean is that the bulb only draws 55W but the output (brightness) will look like if you have a 150W bulb.
specONE
Mar 28, 2016 11:31 AM
mikes rx
Oct 1, 2007 12:11 AM
chaos6458
May 27, 2007 08:35 PM
Sky777
Mar 19, 2007 01:41 PM
GS3-Kid858
Sep 28, 2001 12:12 AM
