Fuse problem
Old Jun 18, 2007 | 05:55 PM
kcw884's Avatar
kcw884
Default Fuse problem
Recently, the interior dome lighting on my 2006 IS250 AWD stopped working, due to a broken fuse. This happened once before, and after replacing the ATM-10 fuse, the lighting worked again with no problems.
This time around however, when I put a new ATM-10 fuse in, it breaks immediately. I hear a very quiet pop (which I assume is the fuse breaking). I've tried six or seven fuses now with no luck.
Does anyone know why this is happening and how I might be able to fix it?
Thanks.
Old Jun 18, 2007 | 06:03 PM
ben_r_'s Avatar
ben_r_
Huh.... do you have the stock bulbs in there?
Old Jun 18, 2007 | 06:28 PM
l1tech's Avatar
l1tech
You have a direct short to ground in the circuit. Have you modified the lighting in any way? If not get it into a shop and have them fix it...shouldn't be to hard to track down the source of the short from looking at the wiring diagram.
Old Jun 18, 2007 | 09:07 PM
kcw884's Avatar
kcw884
I have stock interior lighting; the only mod I have ever made is adding Tanabe NF210 springs to drop the car.
Direct short to ground? How would that have happened?
Thanks for your help.
Old Jun 19, 2007 | 06:00 AM
l1tech's Avatar
l1tech
Talking
Just one of those things, just always keep in mind that if it has ****, tires or likes to @#$@ your going to have problems with it sooner or later
Old Jun 19, 2007 | 07:06 AM
ben_r_'s Avatar
ben_r_
LOL its so true...!
fbrown1
GX - 1st Gen (2003-2009)
Feb 25, 2014 10:19 AM
michaelw
GS - 1st Gen (1993-1997)
Jan 19, 2014 10:37 AM
itsivan
Jan 27, 2013 06:46 PM
poser714
Mar 2, 2008 10:35 AM
