when recieving a call
Old Feb 19, 2007 | 06:18 PM
nehal51086's Avatar
nehal51086
CL Folding 100,000
Default when recieving a call
when i revieve a call and i am in motion the screen does not show anything..which i thought was normal...but i rode in my friends IS 250 and when he recieved a call it showed the name of who is calling even when he is motion....when im not in motion it shows the number and thats it...and yes i do have my contacts stored in car phone book....is there a certain way i need to do it...my contacts were transfered from my phone...
Old Feb 19, 2007 | 06:27 PM
nabisco's Avatar
nabisco
May have something to do with how the area code is stored in your phonebook. When I am in motion I can't see the name.
Old Feb 19, 2007 | 07:12 PM
Irishman06's Avatar
Irishman06
CL Folding 25,000
Yup. Don't store the "1" before every number in your phonebook.
Old Feb 19, 2007 | 07:27 PM
taylorjste's Avatar
taylorjste
i had the same problem.. i went back and modified the entries in the phonebook so that they appeared exactly as they do when i get a call on my phone.. i did have to put 1 in front of a couple of numbers in order to get the name to show for an incoming call.. hope this helps
Old Feb 19, 2007 | 07:38 PM
nehal51086's Avatar
nehal51086
CL Folding 100,000
but if the contacts were sent from the phone shouldnt they be the same?....it does make sence...will look at that tomorow...thanks guys...
Old Feb 20, 2007 | 01:28 PM
inecstaz's Avatar
inecstaz
the names have to be loaded onto the car's phonebook. if not, it won't show the name.
Old Feb 20, 2007 | 02:05 PM
Spencer's Avatar
Spencer
https://www.clublexus.com/forums/sho...d.php?t=193739
Not sure if this will help. But worth a try.
Old Feb 20, 2007 | 02:26 PM
nehal51086's Avatar
nehal51086
CL Folding 100,000
inecstarz and Spencer thank you for the responses however yes they are already in my car phonebook...and my friend has not done the nav hack and his still shows the name....
Old Feb 20, 2007 | 07:06 PM
inecstaz's Avatar
inecstaz
Thats odd... it could be the phone. because I know certain phones don't send all info to the car...
I have verizon and they have limitations on bluetooth up the butt...
Old Feb 20, 2007 | 08:20 PM
IS3CM's Avatar
IS3CM
Is his an 06? Maybe is has to do with the overide button. My 07 shows name, number, ect when stoped but not driving. I wish it would though that way I dont have to look at my phone to make sure who it is.
Old Feb 20, 2007 | 08:59 PM
Bichon's Avatar
Bichon
The override button is for entering destinations and has nothing to do with bluetooth.
The early responses in this thread had it right. Bluetooth sends number, not name. Name only shows up if it is in the car phonebook, and the number matches exactly. When the car is in motion, the number is blanked out. The name, if available, is not.
Old Feb 20, 2007 | 09:27 PM
IS3CM's Avatar
IS3CM
I see when your connected it will tell the name but no number while driving if the match is correct, but when the call is incomming, the screen still just says "incomming call" no name or number.
Old Feb 21, 2007 | 05:13 AM
Bichon's Avatar
Bichon
You sure!?! You see the name when the car is stopped, but when the exact same person calls from the exact same phone number while you are driving, you don't see it?
Old Feb 21, 2007 | 06:01 AM
nehal51086's Avatar
nehal51086
CL Folding 100,000
hmmmm.....it could be the phone....but then the other statment saying that the phone will send the number and if it matches exactly then it will show the name.... i used my sis's phone and called my phone and her number showed up with a 1 in front so i add a 1 to her number in the car phonebook and on my phone....for those of u that say it works for u can u state what phone u have and what service....thankyou
Old Feb 21, 2007 | 06:56 AM
Bichon's Avatar
Bichon
RAZR V3c on Verizon. Worked with both the crippled Verizon firmware, as well as the uncrippled Alltel firmware I later flashed on my phone.
