DRL/Hi beam bulb swap
Old Feb 12, 2007 | 06:00 PM
rhsmd's Avatar
rhsmd
Default DRL/Hi beam bulb swap
i'm not sure if there's another thread, but i'd like some recommendations on swapping out to a brighter, drl/hi beam bulb.
Old Feb 12, 2007 | 06:50 PM
taylorjste's Avatar
taylorjste
https://www.clublexus.com/forums/sho...light=drl+saga
this thread talks about replacing stock DRLs with hoen xenonmatch plus.. they are a pretty close match to the stock HID. i got the hoen fogs and they match the stock hids pretty good.. there's tons more threads.. just do some reading
Old Feb 12, 2007 | 07:00 PM
Gtidan's Avatar
Gtidan
While there are many choices out there for replacing your high beams my recommendation would be either Phillips Vision Plus or PIAA bubs. I've used both and presently have the PIAA in the Lexus. the Phillips are rated 50 percent brighter than stock while the PIAA are double the stock output (claimed by both companies).
Do a google for either and you can get the dope you need. I should tell you both are NOT cheap. You can go cheap but remember in this area you'll get what you pay for..... Good luck
Old Feb 12, 2007 | 07:23 PM
bagwell's Avatar
bagwell
and they'll still be super yellow looking DRL light...just more of it when you click on the hi-beams.
Synetix250
May 7, 2010 04:30 PM
jonnyxboi
Aug 14, 2009 01:02 PM
triplecore
Lighting
Jan 27, 2009 03:02 PM
ns3425
Mar 25, 2008 05:45 PM
llamaboiz
Jun 16, 2007 01:42 PM
