headlight adjustment knobs
Old Nov 17, 2006 | 10:04 AM
gshb's Avatar
gshb
Default headlight adjustment *****
so on pg. 309 of the manual it shows that there are two adjustment ***** for the headlight aim, yet i only see one. so i tried adjusting just the one **** i found and the aim does change. is there another **** or is the manual wrong?
Old Nov 17, 2006 | 12:27 PM
Dj_AmtraX's Avatar
Dj_AmtraX
You really should not mess with that unless you have an alingment machine. What is the reason for doing it?
Old Nov 17, 2006 | 12:51 PM
Orzel's Avatar
Orzel
Default Headlight Adjust
I'd like to know more about the headlight adjustment too. In the manual it's shown as part of the DIY section. Our 250 has the lights set so low, that on low beam you're overdriving them at anything past 20 MPH. Would love to raise them enough that we can get some decent visibility without blinding oncoming drivers. EU IS’s actually have a headlight adjustment control that's on the dash.
On our RX 330, we had to take it to the dealership to have the headlights adjusted (AFS system there too) – made a heck of a difference.
Old Nov 17, 2006 | 12:59 PM
gshb's Avatar
gshb
it would be great if someone here who has factory HIDs could measure the distance from their garage door and measure how high off the ground their headlight is and then measure how high the cutoff of light is on the garage door.
i recently impacted the right side of my car so that after that happened, the right beam is visually much lower than the left. i also compared the beam levels (left vs right) on an ES330 and there is definitely misalignment on my right beam. plus if the instructions are in the DIY section, why cant i do it myself?
Old Nov 17, 2006 | 02:28 PM
javyLSU's Avatar
javyLSU
2IS OG
Hey Nathan - check your PM's. I hope you didn't mess up your car too bad!
Javier
Old Nov 17, 2006 | 05:02 PM
Dj_AmtraX's Avatar
Dj_AmtraX
You should take your car to the dealer/bodyshop and have them adjust the beam.
The height of an ES350 is different than the IS. You should not eye ball the beam height. Use the alignment tool that attach to the headlight assembly.
Old Nov 18, 2006 | 12:09 AM
omgitsroy's Avatar
omgitsroy
alightment tools?
bc6152
Apr 29, 2013 06:26 AM
xtremex626
Oct 16, 2011 01:38 AM
mctuners
Nov 14, 2007 10:59 PM
shikbas
May 10, 2005 07:40 PM
Invisibleman
Apr 16, 2003 12:08 PM
