On a 93 ES300, How do you adjust the headlights horizontally. My driver side low beams are pointed too much towards the right. I adjusted the screws behind the light and they only move the lights up and down...
If you have the owner's manual for your car, look up the section on "headlight adjustment" and you should find the self-explanatory answer. You'll need the same tool to adjust left/right as the one for up/down (it's either an 8 or 10mm socket wrench).
