245/40/19 rub with front wheels? Square setup
Old Sep 18, 2018 | 01:01 AM
monoglot's Avatar
monoglot
Default 245/40/19 rub with front wheels? Square setup
Hi all,
Do you know if 245/40/19 would rub in the front wheels all on stock suspension with full load? Looking to do this with a square tire setup.
If not, would 235/40 work? Or would I have to go to 235/35 for it not to rub?
wheels are 19 x 8.5 +32
Thanks in advance!
Old Sep 18, 2018 | 01:16 AM
smithy63's Avatar
smithy63
I would think this would be ok. I have 19x8.5 +40 with 245/40/19 tyres and have heaps of clearance
Old Sep 18, 2018 | 08:42 AM
TOPENDMS's Avatar
TOPENDMS
Former Sponsor
245/40 tires are nearly 1.5" over factory diameter. You should probably be on 235/35.
Old Sep 18, 2018 | 10:47 AM
jkonquer's Avatar
jkonquer
245/40/18 is ok on a factory wheels for the front. I think it should be ok since the offset vs width of the wheel is similar to the factory ones, but may want to look into 35 instead of 40.
Old Sep 18, 2018 | 06:12 PM
smithy63's Avatar
smithy63
The 245/40/19 tyre is almost exactly the same diameter as 225/55/17 tyres that were standard on my car
Old Sep 18, 2018 | 06:54 PM
smithy63's Avatar
smithy63
Stock 225/55/17 tyres on my car measure 679.3mm diameter and 245/40/19 tyres are 678.6mm so actually just smaller in diameter.
Old Sep 18, 2018 | 06:55 PM
smithy63's Avatar
smithy63
https://www.willtheyfit.com/index.ph...8-5&offset2=40
Old Sep 18, 2018 | 08:54 PM
TOPENDMS's Avatar
TOPENDMS
Former Sponsor
F Sport has 225/40/18 .. which is 1" larger. If that's not your model .. my mistake.
Old Sep 18, 2018 | 09:46 PM
smithy63's Avatar
smithy63
No problem mate-i'm in australia so maybe we had different tyre sizes here. I know we never had 16" rims like you had there but our 17" rims had 225/55/17 tyres and 18" rims had 245/45/18 tyres standard. This is for an LS430-maybe I mistook what car it was intended for?
Old Sep 19, 2018 | 01:25 PM
arentz07's Avatar
arentz07
F Sport has 225/55/18 .. which is 1" larger. If that's not your model .. my mistake.
What?
I have 225/40R18 in the front, 255/35R18 in the rear on my F Sport. And all F Sports have the same wheel and tire sizes.
Old Sep 21, 2018 | 04:50 AM
ShrinkDoc's Avatar
ShrinkDoc
I run 225/50/18's on the front with zero issues (255/45/18 rear). Based on the tire size calculators on the web, you should be fine.
Old Sep 21, 2018 | 03:17 PM
TOPENDMS's Avatar
TOPENDMS
Former Sponsor
Originally Posted by arentz07
What?
Your right. Not sure where that 55 came from. 225/40/18 is right.
Old Sep 21, 2018 | 03:18 PM
arentz07's Avatar
arentz07
Yeah... so 245/40R19 would be about 1.6 inches more than the stock tire diameter. That seems high IMHO.
Old Sep 22, 2018 | 12:27 AM
ShrinkDoc's Avatar
ShrinkDoc
The diameter on my wheels is approximately 3" larger than OEM. It does fill the wheel well while maintaining width, and in the end, the car is 1.5" taller than stock, the ride is significantly smoother, there is zero rubbing, and the speedo offset is 3mph at 60 mph..
It makes sense for the NE given the potholes and ice rocks in the winter.
Rider
IS F (2008-2014)
Jan 19, 2012 07:48 PM
neomedic
Jan 18, 2012 07:55 AM
autoboy
Wheels and Tires Classifieds
Aug 20, 2010 10:56 AM
IS3_FTW
Wheels, Tires & Brakes Forum
Apr 1, 2009 08:24 PM
NoS
Jun 6, 2005 01:39 AM
