Engine cranking/startup noise (merged threads)
Old Oct 14, 2009 | 03:46 PM
  #496
leescape's Avatar
leescape
I never realized that an 10+ hour job was considered an easy fix. Good luck though, at least you'll get a loaner for a couple of days.
EDIT:
And here's a portion of my invoice in case anyone wanted to see it.
Old Oct 19, 2009 | 11:27 AM
  #497
scrmnws6's Avatar
scrmnws6
Does this include the GS300 RWD as well? I have been reading in the different forum sections and there is little mention about the GS300.
My GS300 with 36k miles has a ticking sound coming from the engine bay at all times. Taking it in today after work to see what's up and go from there. Will update whenever I receive anything from the dealer.
Old Oct 19, 2009 | 12:54 PM
  #498
Lets Drive's Avatar
Lets Drive
Originally Posted by intellis
When asked, "does this problem reoccur after it is fix by you all", he said "no, i have not heard of any complaints yet". I really hope this guy is right.
I'd say it depends on the version of the parts and when you had the work done. Over a year ago, I had a previous version of this fix done to my car, when it was the most 'current' available. Since then, further updates have been introduced, and I've had my problem return, only to bring it back to the dealer for the second fix (now, the most current). Since then, the car has been fine, but it hasn't been a span of a year, yet. To say for certain that it won't happen again is a tricky wager, though we can only hope so.
That should just be your injectors, which is normal**. What people are describing in this thread, is a brief but distinct more audible grinding sound on startup.
** https://www.clublexus.com/forums/gs-...ion-noise.html
Old Oct 21, 2009 | 12:06 PM
  #499
intellis's Avatar
intellis
Just received my car back, and there was no noise. I will be listening if it comes back
Old Oct 21, 2009 | 02:10 PM
  #500
nsxiboi's Avatar
nsxiboi
I noticed that the cranking noise happens more often when I start my car at an incline facing upwards. Rarely does it make noise when my car is on level ground. Anyone notice this?
Old Oct 21, 2009 | 03:50 PM
  #501
RshaoKh's Avatar
RshaoKh
Yup, I only hear it when I have to park in my gf's driveyway where my car is facing upwards. Also, about 2 years ago I did hear the occassional cranking noise even on a flat surface but that was when I had to park outside. Now I park in a garage (no incline) and I never hear the noise, unless I'm at my gf's place.
Old Oct 21, 2009 | 03:54 PM
  #502
Phiber's Avatar
Phiber
I hear it when I am parked on a flat road especially parking lots.
Old Oct 26, 2009 | 09:21 PM
  #503
Zeus69's Avatar
Zeus69
Originally Posted by GiantsFan
Im sooooooo glad I don't have this problem.... *knock on wood*. But just in case I do get it, I have gone through EVERY PAGE and copied part #'s, TSB #'s, link to the video, etc in case I need to show my service advisor as"proof"....
This thread is
For those of us too lazy to read every page but who are still having this problem, could you please pass along those above important items? I'm due at the dealer next week. Have seen them twice but they can't reproduce while car is there so won't offer fix. I will catch it on video this week, which they said is adequate to document the problem and cover the repair...
Old Oct 26, 2009 | 10:51 PM
  #504
lobuxracer's Avatar
lobuxracer
Tech Resource
No. The first time mine did it I was on a very flat surface in a parking lot. I'm sooooo glad the F doesn't do this.
Old Oct 27, 2009 | 06:16 AM
  #505
darkIS's Avatar
darkIS
Just out of curiosity, what if I had this noise at startup issue and did not get it corrected. Would it continue on running like normal or will the engine eventually fail? I just don't want a b-rated tech tearing down my engine.
Old Oct 27, 2009 | 06:29 AM
  #506
Lets Drive's Avatar
Lets Drive
The long term effects are unknown, currently, but its something you may want to consider having fixed. A "B-rated" oversight from Toyota is currently causing an obnoxious cam grinding noise, which won't fix itself, whereas the dealer can be held accountable for their service work and a likely fix. I don't think I've read of any cases where people have had problems with specific technical work done, so again, its something to strongly consider if it bothers you enough.
The only other scenario is seeing what happens in the long term, likely when you're out of warranty.
Old Oct 27, 2009 | 09:17 AM
  #507
Technique's Avatar
Technique
CL Folding 500,000
FWIW, I didn't do anything about it and the noise went away by itself... It has been gone for several months now... I feel better this way than having someone tear my engine apart...
Old Oct 27, 2009 | 12:24 PM
  #508
xuningshen's Avatar
xuningshen
I think its funny because the service advisers pretend that they've never heard of the problem before. They know that it is a common issue. Bring it up.
I had mine fixed a 2 months ago. i brought the car in to newport lexus, told them it only happens on cold start up, described it as a starter type(like the starter gear is hitting the flywheel) metal on metal "grind" so they gave me a loaner and i went home.
They started it up the next morning, agreed it had the issue, started working on it right away and they had it fixed and ready for me by 3 oclock. Somebody said it was a 10+ hour job, i had expected to have my car at the dealer for 3 days or so. but they got it done in less than a day. I was amazed lol. no problems again yet.
Old Oct 27, 2009 | 01:05 PM
  #509
lobuxracer's Avatar
lobuxracer
Tech Resource
It may be quiet now, but it's not fixed. It will come back, and likely at a time when you'd rather it didn't. When mine did it in front of my father-in-law (a Mercedes guy), and he looked at me like "This is why you buy Mercedes" I was ready to move on immediately.
Old Oct 27, 2009 | 04:25 PM
  #510
leescape's Avatar
leescape
Wow are you serious? I uploaded the actual portion of the INVOICE and it's right on this page. It contains all the parts numbers and other relevant information.
