Bluetooth V1.0 compatibility
Old Oct 10, 2006 | 09:36 AM
MYIS350's Avatar
MYIS350
Red face Bluetooth V1.0 compatibility
Hey! Does anyone know which bluetooth verision (v1.0, 1.1, 1.2, or 2.0) is compatible with the ISX50? On the Nav manual (P.105), it says,"this system supports the following service: HFP (Hands Free Profile) V1.0, OPP (Object Push Profile) V1.1. If your cell phone does not support HFP, you cannot enter the Bluetooth phone, and take OPP service individually." Does Bluetooth v1.0 has HFP v1.0? Are they related? Thanks alot!
Old Oct 10, 2006 | 10:50 AM
sams_is's Avatar
sams_is
I have Samsung i730 PDA phone which has Bluetooth Version 1.1 with profiles HSP, HFP and OPP.
It seems like that they're happy with each other and my phone doesn't have a problem recognizing my car as a handsfree devices and works fine in that regards. A few glitches includes that my nav screen doesn't show the signal strength and battery level, and I can only transfer only one contact at a time but these seem to be issues with my particular phone only.
So I imagine anything above 1.1 devices are compatible with 2IS but your best bet is to look at your phone's manual. It always tells you what kind of profiles are supported.
Old Oct 10, 2006 | 01:40 PM
omgitsroy's Avatar
omgitsroy
1.0 treo 650
Old Oct 16, 2006 | 05:29 PM
ocdavid's Avatar
ocdavid
First, I'll start off by answering the main questions. Any Bluetooth enabled phone that has the Hands Free profile should work fine. It is possible for a phone to have the Hands Free profile yet not support the OPP (Object Push Profile). The only downside is that the numbers may have to be entered one by one. That being said....
There are 3 major points that you need to look for when dealing with Bluetooth compatibilities and performance.
1. Version - 1.2, 2.0
2. Class - 1, 2, 3
3. Supported Profiles - There are currently 33 different profiles. The main ones that concern cell phones and the handsfree communication are A2DP, HFP, HSP, OBEX, and OPP.
VERSION
The main (or core) VERSIONs are 1.2 and 2.0. The significant difference between the two are data transfer speeds. Version 1.2 has a rate up to 1Mbps and version 2.0 supports up to 3Mbps. This doesn't really matter nor make a difference in the handsfree aspect of Bluetooth.
CLASS
There are currently 3 classes of Bluetooth. The class determines the operating range of the device. Please note that when 2 devices are used and the classes differ, the shorter distance will prevail.
Class 1 = 100 Meters or about 300 Feet. (Primarily used in industrial applications but is being developed for consumer use)
Class 2 = 10 Meters or about 30 Feet. (This covers about 90% of Bluetooth devices)
Class 3 = 1 Meter or about 3 Feet. (Not very common)
SUPPORTED PROFILES
When dealing with Cell phones, you want to mainly focus on the supported profiles of your phone and the device you want to use it with.
Every cell phone that has Bluetooth embeded in it has the HSP or HeadSet Profile, allowing you to use the phone with a Bluetooth headset.
Most cell phones also include the HFP or HandsFree Profile for using the phone with a car kit or speakerphone. The main difference between the HSP and the HFP is that the HFP will also transmit call information such as Caller ID. This is the profile that will be preferred for hooking the phone up to the car kit.
Old Oct 17, 2006 | 06:39 AM
tdrag97's Avatar
tdrag97
2. Class - 1, 2, 3
VERSION
CLASS
SUPPORTED PROFILES
+1 good stuff
Old Oct 17, 2006 | 07:42 AM
IS_Mine's Avatar
IS_Mine
Default Nokia 6265i
Does anyone have a Nokia 6265i?
I looked at Lexus' webpage, however that phone and my carrier isn't listed.
I would like to think it would work but it would be nice if someone else of the forum had the same phone to confirm that. Haha I am getting a Cell just to use it in the car.
Old Oct 17, 2006 | 08:41 AM
tdrag97's Avatar
tdrag97
2. Class - 1, 2, 3
VERSION
CLASS
SUPPORTED PROFILES
I looked at Lexus' webpage, however that phone and my carrier isn't listen.
yea.. mine is not listed either.. but I got mine to work..
I have the sony K750i
Old Oct 17, 2006 | 10:49 AM
ocdavid's Avatar
ocdavid
If your phone has Bluetooth, it should work fine. Some phones have a better implementation (stack) than others, but they will work none the less. The Sony-Ericsson K750i will work without a problem as I have used that phone in my IS. The Nokia should also work totally fine as it has Bluetooth with the Handsfree profile. While it may not have the specs to transmit the battery and signal levels to the display, it should work for calls just fine.
Car9
ES - 7th Gen (2019-2025)
Jul 26, 2019 10:15 AM
EX350BCCA
Mar 7, 2011 02:13 PM
arnelgonce
Sep 8, 2010 02:50 PM
CG lover
Jan 26, 2007 10:28 AM
rtanouye
GX - 1st Gen (2003-2009)
Mar 2, 2006 01:37 PM
