Changing stock sub?
Old Oct 11, 2006 | 06:32 PM
Technique's Avatar
Technique
CL Folding 500,000
Originally Posted by SParker1tx
What if you waned to replace the current Sub with another sub that FIT in the place the stock sub currently is in and add a nicer amp with the new nicer sub?? Would this help w/ the system, and or is it possible??
I'd be interested in doing this myself... But I don't think there are any aftermarket 7.5" free-air subs... Anyone know for sure???
Old Oct 11, 2006 | 08:06 PM
korean32's Avatar
korean32
Default Here is my setup
JL Audio 500/1 Amp with (2) 10" subs
Robert in Guam
Old Oct 11, 2006 | 08:09 PM
korean32's Avatar
korean32
Default My Subs
Robert in Guam
Old Oct 11, 2006 | 08:11 PM
mlee21's Avatar
mlee21
is that air space enough for that sub?
Old Oct 11, 2006 | 08:12 PM
korean32's Avatar
korean32
Default Right side
Robert in Guam
Old Oct 11, 2006 | 08:15 PM
korean32's Avatar
korean32
The sound is a very clean tight bass. This is a custom box made by UTTAM'S here in Guam. It is a 100% improvement in the quality of the sounds.
Robert in Guam
Old Oct 11, 2006 | 08:20 PM
korean32's Avatar
korean32
Default back view
[ATTACH]92601[/ATTACH
Robert in Guam
Old Oct 11, 2006 | 08:25 PM
Technique's Avatar
Technique
CL Folding 500,000
How much was the custom enclosure? What's the cubic feet of the enclosure? Did you disconnect the stock sub?
Old Oct 11, 2006 | 08:35 PM
korean32's Avatar
korean32
The cost of the (2) boxes was $200.00 taking over 3days to make. I wanted the boxes to be flush with the fender area to maximize the space in the trunk so I don't have the exact space of the enclosure of the boxes. He had to cut weird angles to fit. The amp is hooked up to the battery with the signal integrated into the stock amp which is under the right side sub. The subs are so loud that it makes the gas cover rattle.
Robert in Guam
Old Oct 11, 2006 | 08:42 PM
Technique's Avatar
Technique
CL Folding 500,000
Robert in Guam
Did you disconnect the stock sub? Do you have ML?
Old Oct 11, 2006 | 09:07 PM
korean32's Avatar
korean32
No, the stock sub is still installed. The stock is so weak compared to the JLs but the sound with JLs integrate nicely. I do have ML, however, the NAV is not available here in Guam so I can't play DVD-A.
Robert in Guam
Old Oct 12, 2006 | 12:20 AM
linh811's Avatar
linh811
Attachment 92595
Robert in Guam
looks simple and clean! i've been happy with my basslink, but i may need to upgrade
Old Oct 12, 2006 | 12:35 AM
mlee21's Avatar
mlee21
i was first thinking about doing that exact same setup where you have the two subs on the sides, but i figured that you wouldnt be a able to fit golf bags in there so i had to scratch it. :/ atleast by putting it up against the seats, ill be able to fit in one. maybe 2 max.
olddog
Oct 24, 2006 07:40 PM
LEXIOUS
Jul 8, 2006 03:42 PM
blknfury
May 22, 2006 07:01 PM
sc300n00b
12
Jun 24, 2004 08:53 PM
