OEM CD Changer
Old Sep 29, 2006 | 12:39 AM
hguy4x's Avatar
hguy4x
Default OEM CD Changer
Is the OEM CD changer double din? I remember seeing someone replacing it with two alpine units. i forget who that was.
I'm looking to switch it out to put in an Alpine W200.
http://www.alpine-usa.com/en/product...model=IVA-W200
Thanks!
Old Sep 29, 2006 | 01:10 PM
hguy4x's Avatar
hguy4x
anyone know?
Old Sep 29, 2006 | 01:21 PM
cmusic's Avatar
cmusic
That was me that used to have an Alpine F#1 7990 and H900 display in the dash. The factory head was moved to the glovebox.
I never did like the looks of the deck and display in the 2IS dash, even though they are incredible peices. I never did complete the trim panel around them.
I now have the factory head back in the dash and use an Alpine VPA-B222 Vehicle Hub Pro as a master audio/video system controller and a Alpine LCD monitor mounted on a cell phone mount next to the center instrument panel. The factory head plays through the Hub's factory system input.
I actually don't know if the W200 will fit in the location.
Old Sep 29, 2006 | 01:29 PM
hguy4x's Avatar
hguy4x
Oh right that was you! Do you mind me asking why you initially routed the factory head into the glove instead of just using your 7990 solely?
I was going to keep everything stock on the dash and route everything through an H701 (I wanted to retain most of the stock system as I bought Nav). But I didn't know if I needed to buy a JL Cleansweep as well (probably functions the same as your b222 if i'm reading what Alpine says correctly). Then I just thought screw it I'll just see if a w200 fits.
Old Sep 29, 2006 | 02:44 PM
cmusic's Avatar
cmusic
I moved the factory head to the glovebox because if it is removed the A/C stops working. In non-NAV 2ISs the display for the radio and the A/C is on the same circuit board. Remove the head and the display board will shut down.
I am using an Alpine F#1 H900, DHA-680 DVD changer, and maybe a CHA-S624 CD changer with my Hub. I have worked with a W200 and H701 and liked both peices very much. You need to get the PAC TR-7 module to bypass the W200's video and processor safeguards.
If you turn the ASL (Automatic Sound Levelizer) off the factory deck has only a slightly mild eq curve. I personally don't think it needs a cleansweep. It does have a subsonic filter at 30 Hz, but I just boost 20 and 25 Hz on my H900 to compensate for it.
joeker
Jan 8, 2010 10:04 AM
lexusnb
Jan 29, 2008 08:45 PM
gadgeeets
Apr 15, 2007 10:46 AM
Anatoliy
Oct 10, 2002 06:37 PM
