Nav problem
Both times, I glanced down at the map, only to see a location wildly off from my actual location -- probably off by 3 to 5 miles. The first time it looked like I was blazing through fields, the second time it looked like I was jumping around on various (wrong) roads. Both times, I powered off the car in the hope that would fix it, but it didn't. So I used the calibration function to reset the map and direction to my actual location, and things seemed fine after that.
Has anybody else ever experienced this kind of glitch?
From the thread the other day, I learned that my car wasn't made at the Uhura or Tahini or whatever the heck that award winning assembly plant is called. Perhaps the nav installer at the second string factory was busy shmoozing with a co-worker as my car went by.
I have now been keeping track of when my system actually has a valid gps signal simply by seeing the "gps" under the scale marking/compass arrow. When you see "gps" it has a valid signal. Very soon after I see that the car finds its location pretty quickly.
I also am thinking that my car has over 25k on it and the accuracy of the dead reckoning is fading away with my tires....Ill see how things change when I get my new tires....
This problem has three possible sources according to Toyota - first
OK:
The readings are almost the same.
(b) Measure voltage.
(1) Jack up either one of the drive wheels.
(2) Move the shift lever to the neutral position.
(3) Turn the engine switch on (IG).
(4) Measure the voltage between terminal SPD of the
navigation ECU and body ground when the drive
wheels are turned slowly.
OK:
Voltage pulses as shown in the illustration.
navigation ECU connector p2.
(b) Measure the resistance according to the value(s) in the
table below.
Oh, yeah, in the troubleshooting table, they list being able to work the nav buttons while moving as a fault...
First, the fact that the diagnostic says only two satellites are being seen doesn't necessarily mean there is a problem with the car's nav system. Remember, those satellites move in the sky, and it may be that they are in a position where the best signal is simply not being sent to the car.
Also, the reason your position was off on the map was because there was no satellite signal to give you the correct position. I'm not sure how the system in the IS works, but in my Lincoln, when satellite signal is lost, the system figures your position based on dead-reckoning (e.g., measuring speed and distance). Any errors in that calculation can result in a false position.
Its likely the problem will correct itself once a stronger sat signal is received. However, if it repeats, I'd ask the dealer about it. Best of luck.
Does anyone know for certain where the GPS antenna is located? I've seen a few threads that claim it is by the rear view mirror, and one that claims it is under the dash, but I'd like to know for sure. Perhaps some wire jiggling could save me a trip to the dealer.
If the detected error is the antenna, you'll see either code 58-41 or 80-41. If the error is not one of these two, then it might not be the antenna at all.
If you want to try checking the antenna connection, it is the yellow wire on connector A pin 13. The antenna itself is in the center of the dash at the front. Is it possible you have a radar detector or some other device directly over the antenna blocking the signal? (Yeah, I know it sounds really dumb, but I figured it can't hurt to ask.)
