VDIM question
Old Sep 7, 2006 | 10:48 AM
Larry96815's Avatar
Larry96815
Default VDIM question
Lexus web site says VDIM is used to control control loss form car sliding. So if it doesn't "kick in" on a straight away run (drag race) what is to be gained with turning it off with the foot dance? Wouldn't turning off the traction control be all that is needed for drag racing?
Aloha,
Larry
Old Sep 7, 2006 | 10:55 AM
Hartawan's Avatar
Hartawan
Former Vendor
Turning off VDIM you can start drifting, do donuts and all that fun stuff. Maybe a victory dance after the drag. =P
Old Sep 7, 2006 | 11:45 AM
Larry96815's Avatar
Larry96815
So back to the same question, for a drag race wouldn't turning off the traction control be sufficient?
Aloha,
Larry
Old Sep 7, 2006 | 12:23 PM
javyLSU's Avatar
javyLSU
2IS OG
No - the VSC and TRAC (which is really what the original poster was referring to instead of VDIM) WILL kick in on a straight-away. I've had this happen to me several times. If you drive the car normally (with TRAC and VSC enabled) and then drive after doing the pedal dance, you'll feel quite a difference - even in straight-aways. The next time you drive the car normally, you'll really be able to feel the ECU backing off the throttle in some instances and actually applying brake force in others. Try it out, and you'll see! So for drag-racing type situations, I would do the pedal dance.
Javier
Old Sep 7, 2006 | 12:25 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Try it. I haven't. I did the pedal dance because I didn't want any interference at all. It might be OK, and it might not.
Old Sep 7, 2006 | 02:04 PM
Hip_hop77's Avatar
Hip_hop77
Shouldnt make such a big difference..
but i feel like the throttle response and other things got better...
might just be my opinion.
Old Sep 7, 2006 | 02:28 PM
gshb's Avatar
gshb
seriously, go out and try it on some back street. even on a straight away, giving your car some gas (you dont even need full throttle) will cause the tires to squeak a bit. this is especially true on roads that arent perfectly smooth. for extra fun, do it in the rain =D
Old Sep 7, 2006 | 05:29 PM
acsan's Avatar
acsan
If I'm not mistaken, VDIM encompasses all of the car's electronic nannies including VSC, TRAC, etc. so yes it probably would be a benefit having it off.
Old Sep 7, 2006 | 05:57 PM
Gernby's Avatar
Gernby
What bugs me about the traction control disable switch is that it reenables itself every time you go over 30 MPH. If you disable TRAC and VSC with the pedal dance, it stays off until you turn the car off.
Old Sep 7, 2006 | 06:29 PM
javyLSU's Avatar
javyLSU
2IS OG
There is no known way to completely disable VDIM, though.
Javier
sparta3993
Aug 28, 2014 10:55 AM
Kazabet
Nov 20, 2013 12:30 PM
SILENCZ
May 14, 2010 11:04 AM
sammy5001
Apr 20, 2008 10:45 AM
italiandud
Aug 27, 2007 05:18 AM
