Rubbing Really Bad
Old Jul 31, 2006 | 05:45 PM
ChrisM910's Avatar
ChrisM910
Default Rubbing Really Bad
I got my rims about 2 months ago and i went through this website to determine which would be the best size width and what kind of tire size i should get.
i got 19x8.5 in the front with 235/35/19 in the front and whenever i turn the wheel is rubs against something i cant figure it out
in the rear i got 19x9.5 with 275/30/19 and let me tell you anytime i hit like a little hump on the road especially at high speeds or when i have people in the back seat it rubs rediculously.
im going to have to downgrade to 255/30/19 in order to stop rubbing, and im not even a 100% sure that, that will eliviate the problem. If anyone can help me with this matter it would be great sorry i dont have any pics of it up ive been extremly busy but im back now and i will have photos asap.
any help would be greatly appreciated
Old Jul 31, 2006 | 05:46 PM
wolverine's Avatar
wolverine
the offset for the rims might be wrong
Old Jul 31, 2006 | 05:51 PM
ChrisM910's Avatar
ChrisM910
i believe +40 in the front and +42 in the rear
Old Jul 31, 2006 | 05:54 PM
glilly's Avatar
glilly
what are you lowered on? Stock shouldn't rub at all, ...even a slight 1" drop shouldn;t pose the rubbing your describing
Greg
i'm using a +43 front and +45 rear and have very little rubbing in the front, and none that i've noticed in the rear (although I haven't loaded down the rear yet)
ihkskim's Avatar
ihkskim
i say offset~ my car is tucked in the back kinda. and it doens't rub even w/ people int he car
Old Jul 31, 2006 | 05:57 PM
ChrisM910's Avatar
ChrisM910
Greg
im stock hight, i havent touched the suspension, its rubbing rediculously on the fender. its ripping my sidewall apart
Old Jul 31, 2006 | 06:08 PM
TSP350's Avatar
TSP350
I had rubbing with 275/30/19 in the rear. This was due to Kumho tires i purchased being especially wide for the given size. The shop I bought the wheels and tires from had a "wheel lip roller" which attaches to the rear hub and flattens the inside lip. The shop took extra care to heat the wheel arch to make the paint more flexable to avoid cracking. Now the car looks good and doen't rub.
Old Jul 31, 2006 | 06:09 PM
ChrisM910's Avatar
ChrisM910
how much was it to do that
Old Jul 31, 2006 | 06:25 PM
TSP350's Avatar
TSP350
They did not charge me. It took 35-45 min.
Old Aug 1, 2006 | 10:48 AM
ChrisM910's Avatar
ChrisM910
i need to check that out because its rediculous already, if i dont want to go that route what is the best size to get so that i dont rub
Old Aug 1, 2006 | 09:52 PM
TSP350's Avatar
TSP350
Check the Forums for best sizes. Avoid Kumho's as they are wider than other tire brands for the same size.
Old Aug 1, 2006 | 10:16 PM
IS_250's Avatar
IS_250
i doubt you're rubbing any metal on the fender. take a heat gun and heat up the plastic fender liner and push it in. that should solve your rubbing issues. the tires are just rubbing the fender liner.
Old Aug 2, 2006 | 02:11 AM
Wests's Avatar
Wests
heat gun for the front, cut out the lip in the rear fender and you'll be fine. My car is lowered on 20s and I dont rub at all.
Old Aug 2, 2006 | 08:37 AM
glilly's Avatar
glilly
BFG KDW's are the same way, ...one of the reasons I went with a 265 in the rear.
I hate the "stretched look" of these new "VIP" style tires on wide rims, ...just get a proper tire that fits. ...stretched tires won't have as much contact patch with the road as a proper fitting tire.
Greg
Old Aug 2, 2006 | 08:41 AM
sirCharles's Avatar
sirCharles
Michelin Pilot Sport PS2 235/35ZR19F & 265/35ZR19R
This is probably the best all-around setup.
or other brand tires.
