Engine Braking Question....
Old Jul 29, 2006 | 01:49 PM
inecstaz's Avatar
inecstaz
Default Engine Braking Question....
So I keep reading in different threads that engine braking is good and better so you don't wear down your brakes and stuff. But to what extent do people use the engine to slow down?? I was cruising at 80 the other day and slowed down by using downshifting... is this ok??
I was also wondering is it ok on the engine if you downshift, and the rpm jumps up to like 4500-5000??? I was going down a hill and downshifted, and it rev'd up real high....to about 4900.
Old Jul 29, 2006 | 02:00 PM
C280to250's Avatar
C280to250
I usually use engine brake when im on the sports mode speeding and needed to brake a little harder than usual.
Obviously if your in 5th gear you dont drop it at 3rd gear right away go down the gear slowly.
Old Jul 29, 2006 | 02:01 PM
15951's Avatar
15951
You're going to get a lot of differing opinions on this. My $0.02 is that it is much cheaper to replace brakes than engine components. It's completely acceptable to use engine braking on long hills, but I try not to force downshifts and get the revs up when I can hit the brake pedal instead.
tempestv8
Hybrid Technology
25
Jun 13, 2018 04:28 PM
goldenrod
Mar 15, 2018 04:54 PM
moskiter
Nov 5, 2009 02:30 PM
