Night Lighting
Old Mar 11, 2006 | 08:40 PM
ptmIS350's Avatar
ptmIS350
Default Night Lighting
Just wanted to know if you guys are using the dark lighted map on the nav at night or if you leave the white bright one.
Tonight I got in my IS350 for the first time and noticed how bright it was. I turned it down on the dash and the map went to dark backround and it was much better.
So when the headlights go on do you reach over and turn the dash **** to the dark backround map or do you just leave it?
I find it weird having to manually switch it between day and night.
Thanks
Pete
Old Mar 11, 2006 | 08:42 PM
kensteele's Avatar
kensteele
I have never touched mine, it switches automatically. Dark at night and bright during the daylight.
Old Mar 11, 2006 | 09:05 PM
tonyxcom's Avatar
tonyxcom
mine used to do it automatically too, but for some reason it doesn't anymore.
Old Mar 11, 2006 | 09:22 PM
pinoychris's Avatar
pinoychris
If you turn it all the way clockwise it won't switch automatically, if you want it to switch at night time, just turn it counter-clockwise a little bit.
Old Mar 11, 2006 | 10:39 PM
Bichon's Avatar
Bichon
Like pinoychris said, it switches automatically at any setting short of full brightness. I find the white background much too bright for night driving.
Old Mar 11, 2006 | 11:13 PM
Leechiro's Avatar
Leechiro
i left it in day mode (bright) for the first week cause i was so proud of it. then noticed it was way too bright, lighted up my face so people could see who i was in the middle of night as i passed them! anyways, now it switches straight to dark when i turn on my headlights i think.
Old Mar 11, 2006 | 11:51 PM
Kermee's Avatar
Kermee
The most popular setting is turning it all the way clockwise until it clicks to "Always Daytime" mode, then back off counter-clockwise and stop right after it clicks.
Then let the auto-dimmer take care of it. When it's bright outside, the dash lights will be on full-bore with the NAV in daytime mode. When it starts to get dark, the dash lights will back off a bit and the NAV goes into nighttime mode.
In this setting, you should never have to touch the dimmer **** again.
Please note that the sensitivity for the dash lights to change between "daytime" and "nighttime" mode are different from your headlights in auto. In most cases, your headlights will turn on first if set to auto as it is getting darker before the dash/NAV goes into night-time mode.
Cheers,
Kermee
Old Mar 12, 2006 | 01:28 AM
tonyxcom's Avatar
tonyxcom
my headlights are on auto.
my dimmer is just before it clicks to full brightness.
but it still no longer switches to black.
Old Mar 12, 2006 | 02:05 AM
Kermee's Avatar
Kermee
Page 155 of the Navigation Manual.
Next time you're in your car:
#1. If not switched to "Auto" already, switch the headlamps to "Auto".
#2. Hit the "DISP" button.
#3. Make sure "Day Mode" is not enabled. If it is, disable it.
"Day Mode" is a memorized setting, even after the vehicle is turned off. So you people who can't figure out why your NAV system isn't going into "night-mode" even when the dimmer isn't set all the way clockwise... now you know.
Cheers,
Kermee
Old Mar 12, 2006 | 04:53 AM
dkaplan435's Avatar
dkaplan435
Originally Posted by ptmIS350
Just wanted to know if you guys are using the dark lighted map on the nav at night or if you leave the white bright one. ... So when the headlights go on do you reach over and turn the dash **** to the dark backround map or do you just leave it?
Pete
I let it switch automatically. When I'm actually using the NAV at night, I just click on Display and then Day Mode.
When I'm done w/ the NAV, I go back and turn Day Mode off.
Old Mar 12, 2006 | 06:56 AM
ptmIS350's Avatar
ptmIS350
Thanks guys I appreciate your help, I'll make sure my setting are correct and i'm sure it will work
Tom57
Sep 9, 2025 03:29 AM
05RollaXRS
RC F (2015-present)
29
May 18, 2019 09:43 PM
dug320
Hybrid Technology
Feb 13, 2013 06:52 PM
mikevanle
Mar 8, 2007 10:15 AM
AgentWD-40
GX - 1st Gen (2003-2009)
Oct 17, 2005 01:35 PM
