28300 no problems except a clicking noise in the center. sounds like it comes from the radio area. and my driver seats makes a weird noise when im going around a curve or turning. getting that checked out this tuesday. other than that everything else is good!
50k and some change...just got my car out of the dealership last week after a week and a half.
driving down to irvine my radio started tripping, then the power steering went out and all my warning lights came on..car started cutting off and on while driving on the freeway. I finally pulled over and turned the car off and tried to turn back on..didnt do nada!
I thought it was the altinator..had it towed to the dealer and got it back in a couple of days after they replaced the altenator. the same day I picked it up, I drove from Ontario to El Monte..I was getting some tires put on. the car overheated and coolant was everywhere. I let it cool down and put some coolant back in. tried to drive back to work but the same issue as the first time. power steering went out and started to cut off and on....dealer tried to blame it on my tv's and stereo system. after a week they said it was due to the reverse???..dont know how this works, but they replaced it all at no cost. THANKS FOR EXTENDED WARRANTY!!!
(sorry for the long rambling post..lol)
56000 miles. Everything is good except my sunroof. When it's closing all the way, it opens up again at the last minute. When I try few times holding down the rail when it closes, it closes. Weird problem. Other than that, runs perfect.
42,000 here and so far I have had zero problems.... I hope it stays this way also I enjoy the car and having no problems with each and every time makes the car that much more fun to drive.
I'm just over 46k. I'm the original owner, got it in '09 with 23k miles on it. I've had very minor issues like a screw coming loose on mud flap type thing. I found out about the rearview mirror about 4 months too late, and the brakes but those are pretty minor and the brakes won't be an issue when I actually need to change them. I do have that metal grinding noise when I start but happens once every few weeks or so. That I can get fixed still.
And the dealership accidentally nicked my passenger door when cleaning it. It was very small and I had them fix it. Though they did try to say it was my fault.
Mine just turned 36K...2006 IS250 RWD..Only 2 problems..CD player was replaced & volume switch control on the steering wheel has become worn. Dealership replaced the changer under warranty but because they said my hands sweat, they won't replace the volume switch cover...but if I donate $238 to them, they will install a new one for me. WTF! All service campaigns were done with no problems.
you should try a different dealer or maybe even a different service rep. sometimes its all about who you talk to and how you ask
