Vibrating rear view mirror?
Old Jan 23, 2006 | 10:23 PM
ES3's Avatar
ES3
Default Vibrating rear view mirror?
Anyone else notice a problem with theirs? The ML isn't even up to 10 and I notice the vibrations, of course going over bumps I notice it too. I looked and the mirror appears to be solidly bolted down?
Old Jan 23, 2006 | 11:51 PM
2006is350's Avatar
2006is350
Mine also does it
Old Jan 24, 2006 | 04:39 AM
ES3's Avatar
ES3
Hmmm Defect?
Old Jan 24, 2006 | 06:24 AM
jlin101's Avatar
jlin101
it's common in mirrors anchored to the windshield--has nothing to do ML. My RX330 (non-ML), IS350 (ML) and G35C all do the same thing. It's just "harmonizing" with the bass frequency.
Old Jan 24, 2006 | 06:36 AM
cmusic's Avatar
cmusic
Turn your bass down.
I have the standard audio system and my mirror vibrates when I have the bass at 0 or higher. It is normal for the way this system was tuned. Personally I think the Pioneer/Harman engineers put too much bass boost into the system. The bass frequency is boosted around 100 Hz and sometimes drowns out the lower bass harmonics depending on the music played. But the majority of the average buyer likes it, so Lexus left the bass boost in.
My saleman turned the bass to +5 on my test drive and said it sounded great. I frowned to turned it back down to -1. More bass does not equal better sound.
Old Jan 24, 2006 | 09:42 AM
ES3's Avatar
ES3
Actually based on .net, I'm noticing a lot of people who HAVE navigation and rain sensing windshield wipers are noticing the problem more than those who don't have those options, I think because the cluster around the mirror with those options has a different bolt pattern?
Old Jan 24, 2006 | 11:19 AM
Morrissey's Avatar
Morrissey
I don't have ML nor do I have rain sensors, but my rear view mirror rattles too. Usually I just adjust it and the rattling stops.
Old Jan 24, 2006 | 11:32 AM
ES3's Avatar
ES3
Just by moving it up and down?
Old Jan 24, 2006 | 11:44 AM
TheRupp's Avatar
TheRupp
Also happens in my ES300, and both of the GS's
Old Jan 24, 2006 | 02:07 PM
Morrissey's Avatar
Morrissey
Yeah. I'll move it up and down slightly and it'll go away. It comes back later though
Old Jan 24, 2006 | 02:19 PM
PhilipMSPT's Avatar
PhilipMSPT
Cycle Savant
It needs a tighter fit. Use a rubber band or chewing gum...
That's Lexus Klassiness...
Old Jan 24, 2006 | 02:35 PM
shaolin's Avatar
shaolin
how bad is the shake cuz i don't think i have that problem yet....
Old Jan 24, 2006 | 03:27 PM
Bichon's Avatar
Bichon
Cranked my non-ML IS350 up to 45 and the mirror still wasn't shaking. I have the bass set flat (0).
(I'd love to have bass strong enough to shake the mirror without getting muddy. )
Old Jan 24, 2006 | 03:48 PM
kensteele's Avatar
kensteele
It's not bad enough shake to make it unusable but you won't be able to tell if that's a cop car trying to pace you.
Old Jan 24, 2006 | 06:11 PM
Payam's Avatar
Payam
When I turn up my ML I get a some vibration in my mirror when the bass hits. Nothing i'm not used to though.
