Another interesting Service menu found! (adjust bluetooth sensitivity)
Old 04-11-10, 02:21 PM
  #31
3KGTVR4
3KGTVR4's Avatar
Guys it works in my IS250 2009!
But i have the same problem that people are complaining that i sound too far away!
so i have to shout all the time while talking and driving!
Now i have tested on Nokia N95 8gb, N97, and HTC HD2!
Same Result..
And in the hidding setting menue, Have any one tried to change the Bluetooth setting in send and recive ?
Wich Values do you rekomend?
Old 07-07-10, 04:50 PM
  #32
greg0723
greg0723's Avatar
Originally Posted by celmei
Hi Muzzman1,
Sorry to bother you again, I am not good at cars, I would like to adjust my blue tooth as well. Can you let me know where is the parking light switch? BTW, I haven't try it out yet, just would like to clarify it before starting.
"first hold the "info" button (I did it for about 5 secs) then switch your parking light switch from off-to parking lights-repeatedly while still holding the info button....it takes about 5-6 cycles...an poof the NAV screen enter yet another Service menu. From there I navigated to a bluetooth menu where I was able to adjust the Microphone volume higher so that people can hear me better!
that is the switch to the left of your steering wheel that you cut your lights on and off with. also the one you can leave your car lights on auto with i believe.
Old 07-07-10, 05:48 PM
  #33
tC350
tC350's Avatar
Sweet, this works on my mom's 2008 ES as well
Old 07-07-10, 06:21 PM
  #34
MBTC
MBTC's Avatar
Can anyone tell me if its possible to increase the microphone sensitivity if I don't have Nav? The 2010 comes with bluetooth standard even if you don't have Nav.. All the menus are just voice recognition based. I'm guessing the option is there just the sequence of events would be different.
Old 07-07-10, 06:26 PM
  #35
JDKane527
JDKane527's Avatar
Anyone know what the default send and receive settings were at?
Old 07-07-10, 09:09 PM
  #36
SPNinjA
SPNinjA's Avatar
I'm pretty sure it was at 00.
Old 07-07-10, 09:13 PM
  #37
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,861 Likes on 2,341 Posts
There are a number of ways to restore the default settings. I've documented more than 40 service related screens in the nav. If you poke around (literally) you'll find LOTS of feature settings. Unfortunately, despite the hours of poking at the screens, I've not been able to find a menu with the override function in any firmware version after 1600.
Old 07-07-10, 09:21 PM
  #38
JDKane527
JDKane527's Avatar
There's 3 settings you can adjust and the 00 one is the last one.
I'm talking about the send and receive voice volume levels, the two that are above the 00 setting.
Old 10-14-10, 03:45 PM
  #39
soulsoarer
soulsoarer's Avatar
Do you have to up the send and receive or which one do you need to change? What number do you guys have it set as? Also the 3rd one, voice quality I think it is, has anyone change that, to what number, and what does it do?
Old 11-07-10, 05:21 PM
  #40
gjankulovs
gjankulovs's Avatar
I changed my voice quality because my wife always complained about my iPhone 4 sounding like crap thru Bluetooth. It got to the point where she would always know I was calling over Bluetooth and refused to talk to me unless I switched off Bluetooth, so I decided to mess with it. She wasn't exactly a willing helper, so I called with it set on the default value (00). Sounded OK until I started DRIVING then it sounded like crap. I changed it to 50 and she said she couldn't tell a difference. I then changed it to 99 and she said she could still tell I was on Bluetooth, but that it was totally acceptable and that she would be willing to take calls from me when I was on Bluetooth......NICE! I hated having to hold the phone to my ear.
Old 11-07-10, 05:41 PM
  #41
ES3
ES3's Avatar
I've never had luck with clear Bluetooth reception, I either use the speaker cord, holding the phone near my mouth. I mostly just use the iPhone headset for calls.
Old 11-07-10, 05:54 PM
  #42
MashinA
MashinA's Avatar
damn ur wife is bit...............................................ter
Old 11-08-10, 11:08 AM
  #43
650IS350
650IS350's Avatar
Interesting, my 07' IS350 using Iphone4 for blue-tooth no issues, wifey said it works fine and I don't sound like I'm faraway or anything
Old 11-08-10, 06:41 PM
  #44
kartoos100
kartoos100's Avatar
This works on the 2nd Gen IS300 ME Spec. Couldnt figure out most of the menus, but changed the bluetooth Mic thing and it is slightly better.
Old 11-08-10, 07:33 PM
  #45
iRock
iRock's Avatar
my bluetooth has always worked amazingly well
Quick Reply: Another interesting Service menu found! (adjust bluetooth sensitivity)
