Windshield fluid Reservoir
Subscribe
May 9, 2025 | 08:46 PM
I’ve got a 2010 is250 and I need to replace the windshield fluid reservoir, but I cannot find anything on how to replace it, any help would be appreciated.
Reply 0
May 10, 2025 | 06:52 AM
REMOVAL
1. DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL (for HID Headlight)
2. REMOVE COOL AIR INTAKE DUCT SEAL 2010 MY IS250 IS350 [08/2009 -        ]; EXTERIOR: FRONT BUMPER: REMOVAL+
3. REMOVE ENGINE ROOM SIDE COVER LH 2010 MY IS350 [08/2009 -        ]; 2GR-FSE ENGINE MECHANICAL: ENGINE ASSEMBLY: REMOVAL+
4. REMOVE FRONT UPPER FENDER PROTECTOR LH 2010 MY IS250 IS350 [08/2009 -        ]; WIPER AND WASHER: FRONT WIPER MOTOR: REMOVAL+
5. REMOVE RADIATOR GRILLE PROTECTOR 2010 MY IS250 IS350 [08/2009 -        ]; EXTERIOR: FRONT BUMPER: REMOVAL+
6. REMOVE FRONT BUMPER ASSEMBLY 2010 MY IS250 IS350 [08/2009 -        ]; EXTERIOR: FRONT BUMPER: REMOVAL+
7. REMOVE HEADLIGHT ASSEMBLY LH 2010 MY IS250 IS350 [08/2009 -        ]; LIGHTING: HEADLIGHT ASSEMBLY: REMOVAL+
8. REMOVE NO. 3 COOL AIR INTAKE DUCT SUB-ASSEMBLY
(a) Remove the 3 front fender liner LH screws.
(b) Disengage the engine under cover clip.
(c) Remove the 2 bolts, the screw, and the No. 3 cool air intake duct sub-assembly.
9. DRAIN WASHER FLUID
(a) Remove the washer hose from the windshield washer motor and pump assembly, and drain the washer fluid.
10. REMOVE WINDSHIELD WASHER JAR AND PUMP ASSEMBLY (w/o Headlight Cleaner System)
(a) Disconnect the 2 connectors.
(b) Remove the bolt.
(c) Pull the upper part of the washer jar and pump upward to remove it from the windshield washer jar and pump assembly.
(d) Remove the 3 bolts and the windshield washer jar and pump assembly.
Reply 1
May 10, 2025 | 11:41 AM
You might try a couple of Auto Body Shops for this; they are well versed in disassembling (and reassembling!) these body parts and might knock this out for you quicker and cheaper than a Dealership or customary repair shop.
Reply 1
May 12, 2025 | 05:27 AM
You’re a life saver, thank you!
Reply 0
Subscribe
