I decided to create a new thread to get attention from anyone else who has the VLAND LED headlights. They were installed recently they look great gives car new updated look.
BUT they are causing EMI interference/static with the car radio its annoying! Has anyone found a solution to this???
Im researching solutions--FERRITE BEADS and EMI BLOCKING FABRIC. With the beads I might have to take the headlights out which I dont want to do, the fabric I can wrap the backside of the headlight unit while in the car, dont know if it will work but worth a try!
to my knowledge Vlans are LED lights. That being (i think) the case, there would be no switching power supply or boost circuitry needed. That is usually what causes EMI.
I would start looking at the grounds of both systems. Make sure they are all clean and solid. It would be good (if you know how) to measure potential difference (Voltage) between the grounding points of both systems with respect to the actual ground terminal of the battery.
LED lights can sometimes cause car radio interference due to the electromagnetic interference (EMI) generated by their power supplies,; this interference can be picked up by the car radio, causing static or noise on the signal.
