Radiator hose (Upper & Lower) inquire
Old Nov 29, 2024 | 12:30 PM
ELexis's Avatar
ELexis
Default Radiator hose (Upper & Lower) inquire
Interested if members have used an aftermarket equivalent to the OEM Upper radiator hose (16571-31170) and Lower radiator hose (16572-31250)
HPS Reinforced silicone hose kit 57-1267-BLK etc.?
Old Nov 29, 2024 | 12:40 PM
Great purchase if you hate having money in your pocket. What's wrong with the original hoses? If I had to choose aftermarket I'd go Dayco.
Old Nov 29, 2024 | 02:18 PM
ELexis's Avatar
ELexis
No issue with the OEM hoses. Interested if any advantage with the silicone hose and if they fit without issue as with the OEM radiator molded (EPDM rubber ?) hose.Does the lower hose manufactured by Dayco / Gates etc. have to be cut to length, or come pre-molded as with the lower hose and OEM hoses?
Believed Sumitomo manufactured the OEM hose, but may be incorrect.
Old Nov 29, 2024 | 02:39 PM
Aftermarket hoses are pre-molded unless the description says "cut to fit". Silicone has this mystique to it for some reason in reality silicone is not that durable for example silicone vacuum lines don't last at all compared to original which I believe are neoprene.
If ain't broke don't replace the OE parts.
Old Nov 29, 2024 | 04:35 PM
ELexis's Avatar
ELexis
I understood the silicone hoses (HPS / ThermalFlex etc., assume completely made from silicone), had an advantage where extreme heat is a concern, over OEM EPDM due to silicone having higher temperature resistance / tolerance. Is use of special clamp may be needed when using silicone (lined clamp / constant torque clamp) ?
Old Dec 3, 2024 | 02:50 PM
MikeFig82's Avatar
MikeFig82
https://mammothparts.com/blogs/news/...20over%20time.
Old Dec 3, 2024 | 06:19 PM
ELexis's Avatar
ELexis
Thank you Mike!
Cons of Silicone Radiator Hoses:
Permeability:
Silicone hoses can be more permeable than rubber, potentially allowing small amounts of coolant to escape over time.
Cons of Rubber Radiator Hoses:
Limited Temperature Range:
Rubber hoses may not perform as well as silicone hoses in extreme temperature conditions, limiting their suitability for high-performance or specialized applications.
Susceptibility to Wear: Rubber hoses can be more prone to wear and degradation over time, especially when exposed to heat, chemicals, or ozone.
Shorter Lifespan: Due to their susceptibility to wear, rubber hoses may need to be replaced more frequently compared to more durable materials like silicone.
Lexus1uz
Mar 11, 2024 08:35 PM
ChevelleZZ502
Nov 6, 2023 09:24 AM
Bocatrip
Sep 27, 2022 11:07 AM
AWDO1
Oct 3, 2017 01:25 PM
Blk04GS430
Oct 11, 2010 01:54 AM
