Hello, I own Lexus IS 250, 2006 RWD. specifically the 153KW version. I'm in Estonia, therefore car must be European version (I'm not sure if there's difference between these cars made for different geographical markets). I was told by Lexus dealership in Estonia to swap my ACTUATOR ASSY, BRAKE, which i think is the ABS Pump of the car. As i have the VSC lights on as well as the traction light on. I've been told that the computer shows an error in the front left ABS sensor, i've changed the sensor already 2 times. second time i also changed the bearing that came with it and installed an original bearing with the sensor. Now the error still remains, they've checked and all of the wires are working and sensors measure speed, so they've ruled out all of those and think the Module needs to be changed. Now i'm left with finding a used one by myself (as the original according to Lexus costs 3700 EUR
), but i'm not sure if the pumps with other codes match as well. Lexus told me that code for mine is, 44050-53061. I wasn't able to find a module with this exact code. So my question is, do the codes have to match 100%, and what are the better website where i could find a good one ABS module that can be delivered in EU?
