Ball joint inquiry
If needed, additional information with changing out the Lower Control Arm bushings located here;
Lower Control Arm Bushings...
https://www.clublexus.com/forums/is-...ushings-6.html
LCA bushing replacement help
https://www.clublexus.com/forums/is-...ment-help.html
- Left Front lower ball joint (part 4334039505)
- Right Front lower ball joint (part 4333039625)
- Left Outer tie rod end (part 4546430060)
- Right Outer tie rod end (part 4546330130)
- Left or Right inner tie rod (part 4550330070)
- Inner tie rod boots (part 4553559065)
- Tie rod washer (part 9021414011)
During the process, dealership damaged driver side speed sensor (part 89543-30260).
Awaiting replacement however, interested in knowing if the wire / clip that connects to the wheel sensor, is available separately, and if so, what the part number is?
I ask because it appears that the Driver side wheel sensor itself looks good, but the connector is missing (assume technician taped up the end tp prevent being damaged until repaired, see Photo 1).
I base this assumption from viewing the Passenger side speed sensor (Photo 2), and assume both sensors and connectors would look the same.
PHOTO 1 (Driver side sensor 89543-30260 / damaged)
PHOTO 2 (Passenger side sensor 89542-30260)
Would you know if the damaged speed sensor will also impact the ABS and Transmission shifts, in addition to the VSC and Traction control?
