Electrical Issues
Old Apr 30, 2023 | 05:20 AM
XYZ123's Avatar
XYZ123
2nd gear
Unhappy Electrical Issues
Hello forum!
I just have quite a few issues with my Lexus IS250 2008 model as listed below:
  • Engine rumbles at times
  • Clock does not work properly
  • Reverse camera guide does not work properly
  • Temperature gauge does not work at all
  • Fuel indicator jumps around and does not give an accurate indicator of the fuel remaining
  • Headlights are weak
  • Multi-information display does not work except for the speed of the car
  • Powersteering does not work
  • Break system warning light on
  • SRS warning light on
  • ABS warning light on
  • P/S warning light on
It's quite a long list and I have come to think its an electrical issue. I have checked with an electrical car mechanic and he mentioned it had something computer responsible for communicating with the electrical units not working. However, the mechanic himself has never seen this issue before and I am unsure about where to go next with this.
Any help possible would be much appreciated.
Image of the dashboard and warning signs:
Old Apr 30, 2023 | 06:23 AM
Protholl's Avatar
Protholl
Check your alternator
Old May 1, 2023 | 03:59 AM
XYZ123's Avatar
XYZ123
2nd gear
Thanks will do and see how it goes!
Old May 2, 2023 | 02:51 PM
2013FSport's Avatar
2013FSport
Looks like some hooked up the battery backwards. Do a search for checking fuseable link. It's under a clear cover by the battery. Hard to see accurately actually. It's like checking a regular ATC fuse, look for an opening in the Z. If one is found, replace the whole fuseable link.
All connections should be checked for corrosion, loosening, burning. Have a shop check battery snd alternator.
User874
RX - 3rd Gen (2010-2015)
Oct 30, 2022 02:26 PM
JefDav84
Jun 20, 2017 07:01 PM
Is30002
IS - 1st Gen (2001-2005)
Mar 26, 2016 12:10 PM
DaveMcKenz
Nov 24, 2009 07:56 PM
kjbro
Dec 6, 2002 04:43 PM
